Help!! pls - Router Forums
post #1 of 4 (permalink) Old 03-30-2011, 02:56 PM Thread Starter
Country: India
Default Help!! pls
Hey guys i have a pppoe connection coming through ethernet line. i.e i need to use dialer that i have created on the desktop..and i have bought a new Linksys E1000 router v2.1..now my problem is that
1) After entering all the settings correctly my router worked for 3 days after that the net is not working.i.e it cannot connect to the internet keeps giving the error cannot get IP from PPPOE
(i have connected my router in pppoe mode and use the router status page to connect and disconnect)
I have also updated the router to the latest firmware 2.1.01 and after that the problems have started.
My Net works if i directly plug the Ethernet cable in the PC.the problem starts when i connect it to my router.
I have tried power cycling.
I have tried Hard Reset.
dont know what the problem is
I wanted a detailed guide on what settings to use in pppoe mode of the router i.e all the DHCP etc etc..
2) I wanted to know if it is possible to use my pc Dialer only to connect to net irrespective of my router being power on or off??
Guys pls help me Thanks in advance
kratos is offline
post #2 of 4 (permalink) Old 03-30-2011, 04:45 PM
As long as you have a dial-up account of some kind I don't see why you couldn't. However, as this is a woodworking forum, I don't know how much help you are going to get here.
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 03-30-2011, 06:31 PM
woodjoiner's Avatar
First Name: Leon
I thank we have a loose connection somewhere, you thank?
You learn by doing, so I've learned. It's only a suggestion, It's not law.
If I said something let me know, good or bad.
woodjoiner is offline
post #4 of 4 (permalink) Old 03-30-2011, 10:05 PM
First Name: Doug
Does anybody pay any look to see that its a forum for woodworking?
dougj71 is offline
Duplicator - advice and comments pls. allthunbs Jigs and Fixtures 6 02-27-2013 05:30 PM
dissimilar metals - engineers pls help allthunbs DIY and Renovation 5 10-05-2010 06:03 PM
radial drill press experiences pls. allthunbs Tools and Woodworking 6 07-03-2010 06:08 AM
Someone with CNC or good at sign making? PLS Evil Scotsman CNC Routing 8 12-23-2009 07:16 PM
sawhorse suggestions/designs pls. allthunbs Tools and Woodworking 3 11-25-2009 08:20 PM
