Trend T11 collet problem - Router Forums
post #1 of 13 (permalink) Old 04-02-2011, 12:35 PM Thread Starter
First Name: Gareth
Default Trend T11 collet problem
Hello, my first post
Just bought a trend T11 and seem to have a problem with the collet, the collet is already fitted in the locking nut, when I fit a cutter and tighten the nut it just won't hold, I can simply remove the cutter with minimal effort. The nut seems to be going all the way to the end of the thread. I would call Trend but need to use the router over the weekend.
Any suggestions. Thanks
GarethHarvey is offline
post #2 of 13 (permalink) Old 04-02-2011, 01:43 PM
gav
Country: Croatia
First Name: Gavin
Make sure the collet its the right one for the bits shank size. I think that router is fitted with a 1/2 inch collet. Are you using 1/2 inch bits ?
Remove the collet and slip a bit into it. Does it fit snug or is it loose as a goose ?
gav is offline
post #3 of 13 (permalink) Old 04-02-2011, 01:57 PM Thread Starter
First Name: Gareth
It is a 1/2 inch collet and a 1/2 inch bit, the bit fits but not very snug, I would guess there is .5mm play, the collate is just not closing when I tighten the nut
post #4 of 13 (permalink) Old 04-03-2011, 12:44 AM
Country: Germany
First Name: Titus
Gareth,
It sounds like you have a 1/2" collet (12,7mm), are you sure that the bit is 1/2".
About 0.5mm play is very close to 0.7mm which is the difference between the metric and imperial collets.
I have a T11 with a 1/2" collet and it grips 1/2" bit perfectly, I have a reducer sleeve for 12mm bits.
Cum Catapultae Proscriptae Erunt Tum Soli Proscripti Catapultas Habebunt
Titus A Duxass is offline
post #5 of 13 (permalink) Old 04-03-2011, 03:29 AM
First Name: david
Send a message via AIM to drainman
there is a specal locking thread with the t 11 it tightens up so if you think its tight it isnt you then have to tighten some more its the same with loosening i throught ide cross threaded it but that is the safty way that trend work
drainman is offline
post #6 of 13 (permalink) Old 04-03-2011, 03:41 AM Thread Starter
First Name: Gareth
Originally Posted by Titus A Duxass View Post
Gareth,
Thanks, this is the problem, the cutter is 12mm, will have to order a new collet. I assumed it was 1/2 inch.
post #7 of 13 (permalink) Old 04-03-2011, 06:33 AM
dutchman 46's Avatar
First Name: Howard
IIf You haven't used it yet, return it for the 1/2 in. bit
John 3:16
dutchman 46 is offline
post #8 of 13 (permalink) Old 04-03-2011, 06:40 AM
Country: Germany
First Name: Titus
Trend do a reducer sleeve 1/2" to 12mm for about a ten worth it if you can't swap the bit.
post #9 of 13 (permalink) Old 04-03-2011, 08:43 AM Thread Starter
First Name: Gareth
Thanks, I have used the bit before with my old router so returning it is not an option. Will see if I can find a reducer
post #10 of 13 (permalink) Old 04-04-2011, 12:46 AM
Country: Germany
First Name: Titus
Trend no longer have them on their website(s).
I have found another supplier but they are German.
- www.sautershop.de
If you can't find one in the UK give me a shout and we'll sort it out for you.
Problem with Craftsman router collet barking spider General Routing 4 01-16-2011 08:18 AM
Swap: SWAP - Trend T11 1/2 Collet Titus A Duxass Woodworking Classifieds 1 12-26-2010 10:49 AM
M12V Collet Problem golfeng General Routing 4 10-27-2010 05:08 PM
Trend T11 EK HDS General Routing 11 08-01-2010 02:59 PM
Elu router collet problem rockinrolly General Routing 3 02-16-2010 11:50 AM
