Freud Collet Stuck - Router Forums
post #1 of 3 (permalink) Old 04-06-2011, 09:19 AM Thread Starter
Texastom's Avatar
Default Freud Collet Stuck
I have a 3-1/4 hp Freud router. I have a hard time removing the 1/2 shank bit after I'm finished. The nut is completely off the mounting threads. Do I use some type of lube? The collet is clean and free of rust.
Thanks,
Texastom
Texastom is offline
post #2 of 3 (permalink) Old 04-06-2011, 10:06 AM
Hi Tom
Take the nut down to the store and have them replace it, NO lube, if the nut is not damage the bit should come right out, in fact the nut is made to lift the bit a little bit so it's free..if someone put a wrench on the nut without a bit in place it will deform the nut just that little bit..and you will get that error.
Thanks,
Texastom
post #3 of 3 (permalink) Old 04-06-2011, 01:20 PM Thread Starter
Texastom's Avatar
Thanks,
I compared the nut to a working unit. The collet does not snap into the "bad" nut.
Looks like my collets are ok, it's the nut that's worn.
Thanks,
Texastom
Texastom is offline
Stuck Collet Dewalt 625 ogee General Routing 12 11-10-2018 10:56 AM
Freud FT 2000E collet too tight Dr. Putter General Routing 7 02-20-2012 03:16 PM
Stuck collet on router - help tkm795 General Routing 5 01-13-2011 08:53 PM
Freud FT3000 collet? ezatt Starting Off 4 01-19-2007 03:54 PM
