Collets for Ryobi R-600 Router - Router Forums
 3Likes
post #1 of 14 (permalink) Old 04-06-2011, 04:22 PM Thread Starter
chocoearl's Avatar
First Name: Earl
Default Collets for Ryobi R-600 Router
I purchased two Ryobi 3 HP, model R-600 routers. I need 1/2" collet and 1/4" bit adapter for the 1/2" collet. Toolspartsdirect.com list the 1/2" collet (item # 6072223) as no longer available.
Any suggsestions of where I can get these? i alos need a base for the router so I can use the template bushings.
Earl
chocoearl is offline
post #2 of 14 (permalink) Old 04-07-2011, 11:06 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Earl
Leigh do the relevant adaptor for your guide bushes
Leigh Industries - Joining Tradition With Today You need their part No 702.
I haven't found a source of collets for you yet. Are these the Bosch type with a captive nut? I know the Ryobi 2100 model uses something similar.
Cheers
Peter
istracpsboss is offline
post #3 of 14 (permalink) Old 04-07-2011, 11:33 AM
Earl
Hi Earl - Welcome to the forum
Are you sure the model # is right? The only thing I can find close is a Ryobi r600 which is a small trim router. The only other hit I got off google was a R600 on Craigs list with a very limited description.
John Schaben
jschaben is offline
post #4 of 14 (permalink) Old 04-07-2011, 11:58 AM
Amazon.com: Milescraft 1211 Base Plate Metal-Nose Bushing Set for Routers: Home Improvement
MLCS Woodworking Adaptor Bushings and Ball Bearing Guides
Earl
post #5 of 14 (permalink) Old 04-21-2011, 06:42 PM Thread Starter
chocoearl's Avatar
First Name: Earl
I found replacements at erereplacementparts.com
Earl
post #6 of 14 (permalink) Old 07-13-2011, 03:11 PM
First Name: stuart
hi buddy
ryobi will ship parts asap if u contact them direct
luck
stuart england
stuartwatson is offline
post #7 of 14 (permalink) Old 07-14-2011, 04:59 PM
Phil P's Avatar
First Name: Phil
Hi John
The R600 and R601 were/are single speed routers, the RE600 and RE601 were/are variable speed. Certainly listed as such in Europe and all appear to be very similar. I have parts lists for them all and I'll upload them if you'd like. Main difference seems to be different armatures as the RE601 was/is more powerful
Regards
Phil
Phil P is offline
post #8 of 14 (permalink) Old 07-18-2011, 12:47 PM
First Name: stuart
hi earl
ryobi will ship direct mate in uk
not sure where u reside buddy but u should contact them direct and they will asssist
luck
stuart
england
post #9 of 14 (permalink) Old 03-31-2018, 06:25 PM
Originally Posted by phil p View Post
hi john
the r600 and r601 were/are single speed routers, the re600 and re601 were/are variable speed. Certainly listed as such in europe and all appear to be very similar. I have parts lists for them all and i'll upload them if you'd like. Main difference seems to be different armatures as the re601 was/is more powerful
regards
phil
phil
i have the re600 ryobi router and i found your forum i need the 1/2 collet for it could you send me the place where i could maybe get the collet from. My email address is
deleted by moderator
thanks in advance
richard
RICHHOPPY is offline
post #10 of 14 (permalink) Old 03-31-2018, 10:21 PM
Hi Rich and welcome. The forum owners don't allow personal email addresses to be posted on the open forum for security reasons. We have a private messaging system we use to share info like that which you will be able to use after you reach 10 posts.
Phil hasn't been on the forum in a while but if he hasn't changed his email address you might still be able to PM him. Or possibly another member may be able to help you.
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
chicago router reducer collets douger1 Tools and Woodworking 1 03-29-2009 03:25 PM
