Bosch 1617evs switch prob - Router Forums
post #1 of 2 (permalink) Old 04-08-2011, 04:57 PM Thread Starter
First Name: STEVE
Default Bosch 1617evs switch prob
Any easy fix or must I take to dealer?
steve925 is offline
post #2 of 2 (permalink) Old 04-11-2011, 11:24 AM
MikeMa's Avatar
Hi Steve,
You have two options, and both are easy fixes. The first one is contact Bosch, and they will send you a new switch. This is a known issue on the older versions of the router.
Since the first option still requires you to open the router and pull out the switch, option 2 may be worth trying as well. The problem is that the switch isn't sealed and sawdust gets into it. Once you get it out, the switch will pry apart fairly easily, though you will need something very flat to assist you. There are several small pieces inside the switch so be careful. Once the sawdust is cleaned out, reassemble the switch. You will know it is put back together right as it will click on and off as it should. Put the switch back into the router, and it should now run good as new.
MikeMa is offline
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 08:33 PM
Bosch 1617 EVSPK switch problem?? Toolfreak Tools and Woodworking 18 12-17-2015 04:22 PM
Bosch Router Switch Problem bill kay General Routing 41 11-19-2010 08:29 AM
Bosch 1617evs and PRL v2 Paul Stroik Table-mounted Routing 2 04-30-2010 05:58 AM
Bosch 1617EVS router repair chiswoo Starting Off 6 07-02-2007 05:30 PM
