Oval/ellipse routing - Router Forums
post #1 of 13 (permalink) Old 04-09-2011, 10:04 PM Thread Starter
Country: Mexico
Default Oval/ellipse routing
Hi, I have just bought a house at Lake Chapala, Mexico and having a great time making furinture for the house. My next project is to make a oak and wallnut oval coffee table 6ft by 4ft and would like to know how to make a router jig to cut ovals. I intend to construct the table out of 1 inch boards glued together. with inlays of other ovals within the table.
Do you have jig info that I can copy that will work for this project?
Regards - Rick Jenkins - way down in Mexico
rickjenkins is offline
post #2 of 13 (permalink) Old 04-09-2011, 10:28 PM
mpbc48's Avatar
Rockler has a jig for that.
Rockler Ellipse/Circle Router Jig - Rockler Woodworking Tools
I can't tell by the picture how it works, but I know there will be someone here that does and you can probably make your own.
PS. Check out the viideo... it is doable.
mpbc48 is offline
post #3 of 13 (permalink) Old 04-09-2011, 11:02 PM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 13 (permalink) Old 04-10-2011, 02:40 AM
Mike Wingate's Avatar
First Name: mike
Trend make one also.
Mike Wingate is offline
post #5 of 13 (permalink) Old 04-10-2011, 07:20 AM
gav
Country: Croatia
First Name: Gavin
You could make your own, others have done so with success.
My take on an oval jig - WOOD Community
oval jig 018 Midlothian Woodworks
gav is offline
post #6 of 13 (permalink) Old 04-10-2011, 07:23 AM
G'day Rick.
Welcome to the router forum.
The Rockler ellipse jigs only go to 52" in major axis, but you could use that jig to make a template which you could increase in size using a template guide and on of BJ's famous doughnuts.
Sydney, Australia
jw2170 is offline
post #7 of 13 (permalink) Old 04-10-2011, 10:36 AM
Hi Rick
Here's just one place you find all the info you will need to make your own, Bob and Rick of the RWS will show you how to make your own and and how to use it..
See the 3 videos on Ovals
The Woodworking Channel Video Library
post #8 of 13 (permalink) Old 06-24-2011, 10:53 AM
Country: France
First Name: louis jean
Send a message via Yahoo to lerrob
hi Rick
a link for ovals
Les copeaux de jean-marie
lerrob is offline
post #9 of 13 (permalink) Old 06-25-2011, 08:19 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
tres interesant !
istracpsboss is offline
post #10 of 13 (permalink) Old 06-25-2011, 01:28 PM
Guest
First Name: Regis
Rick and Peter,
Here's another jig you can make at very low cost:
Router Jig for Ovals and Circles | Making Ovals & Circles Routers
The larger the plywood square, the larger the ellipse. I'd start around 20" square for the size you want. Make the arm about 36" long.I didn't compute the actual sizes you'll need for a 6'long by 4' wide table top. I use this jig to make 1/2" MDF patterns and then pattern-route the table tops. You will need a pretty large work table for this operation, say a 4'x8' sheet of plywood or MDF and routing MDF makes a heck of a dusty mess. Make your pattern outdoors if possible, unless, of course, you have a Festool router and dust capture system.
Regis
48394 is offline
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
A routing tutorial for beginners Part Four harrysin Guide Bushings and Templates 23 04-21-2013 09:31 AM
New to Routing and already lost!!! sarahrodgers New Member Introductions 10 12-31-2012 11:30 PM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 04:24 AM
JIGS CAN MAKE ROUTING SAFER!! (lesson learned for a newbie) metzgeri Jigs and Fixtures 44 01-25-2011 11:00 AM
