plywood dado - Router Forums
post #1 of 17 (permalink) Old 04-12-2011, 08:05 PM Thread Starter
First Name: Salem
Default plywood dado
Can I use a router to cut Dado on plywood sheet
woodwork is offline
post #2 of 17 (permalink) Old 04-12-2011, 08:21 PM
walowan's Avatar
First Name: Michael
Of course you can, the sharper the bit the better the cut. You might try a down spiral bit to reduce tear-out.
walowan is offline
post #3 of 17 (permalink) Old 04-12-2011, 08:27 PM
Hi Salem, Welcome.
If you are going to fit ply into your dado, they make bits that are undersize for a better fit. 3/4" ply is not always 3/4". Its usually undersize. Same for the other sizes of ply. If it's MDF that usually is ok unless it is MDF light which is thinner like ply.
Undersized Plywood Router Bit Set - Rockler Woodworking Tools
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #4 of 17 (permalink) Old 04-12-2011, 09:08 PM
Hi
Compression Up/Down Spiral Router Bit
This 2 flute solid carbide bit is needed to get clean, chip-free and splinter-free cuts in composite sheet goods such as Melamine or 2-sided Formica/Laminates and veneered plywood.
The Up-shear/Down-shear design of the bit cuts toward the center of the sheet from both sides at once, saving time and eliminating waste.
MLCS solid carbide router bits
post #5 of 17 (permalink) Old 04-12-2011, 09:29 PM
G’day Salem
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #6 of 17 (permalink) Old 04-14-2011, 03:22 PM Thread Starter
First Name: Salem
Thank you for the answer, I was told never rout plywood
I am in fact planning to use 19 ply plywood inported from russia by Langevin et Forest, as the layers are very thin I am expecting this wood to behave like a solid wood but you never know, I will try finger joint but most likely will revert back to Dado if I experience tearout.
Thank you
Salem
woodwork is offline
post #7 of 17 (permalink) Old 04-14-2011, 03:25 PM Thread Starter
First Name: Salem
thank you, this forum looks very interesting, I am already finding lots of answers to my questions
woodwork is offline
post #8 of 17 (permalink) Old 04-14-2011, 03:34 PM Thread Starter
First Name: Salem
Thanks Jame I am in fact planing to use an undersized bit and cut 2 times, I have an other question is a plywood bit would make a cleaner cut?
Thank you
Salem
woodwork is offline
post #9 of 17 (permalink) Old 04-14-2011, 10:13 PM
Salem,
James posted a link to a video recently showing how to make a router guide for cutting grooves. Maybe if he sees this he will repost it. It is a thick piece of mdf or plywood which acts a fence glued to a thin piece of plywood which is wide enough that you have to cut a bit off when you make your first router pass. This shows where your bit will cut. (You have to keep using the same bit every time of course). All you have to do that way is to put a piece of your plywood edge down on the piece you want to rout and pencil mark it. Place the guide on one line and cut then put the guide on the other line and cut that side. Doesn't matter what your plywood thickness is, you will always use the same bit. When you make the guide use a factory edge for the side the router will butt against. The other side doesn't matter.
post #10 of 17 (permalink) Old 04-15-2011, 03:12 AM
First Name: Gareth
I done a lot of this recently, our 3/4 ply in the uk is actually 18mm, I bought a 18mm bit and it done the job with excellent results
GarethHarvey is offline
Dado Jig for Plunge Router bobj3 Jigs and Fixtures 35 01-22-2010 01:01 PM
MDO for table top ebbonk Table-mounted Routing 1 01-04-2010 07:53 AM
Dado on 2 sides of 3/4 plywood for cubby shelves aquilja4 General Routing 3 11-06-2009 08:17 AM
Dado cuts in plywood BK9MJE Tools and Woodworking 4 04-18-2009 01:28 PM
