Triton dust hose? - Router Forums
post #1 of 5 (permalink) Old 04-13-2011, 04:04 PM Thread Starter
Default Triton dust hose?
From what I can tell, my Triton 3 1/4 HP router takes a 1.5" (outside diameter) hose, but I can't seem to locate one. This doesn't appear to be a standard size...
Anyone know where I can find a compatible dust hose for this thing, or has anyone found an acceptable work-around?
Jase is offline
post #2 of 5 (permalink) Old 04-13-2011, 05:55 PM
Hi -Welcome to the forum
What's the ID/OD of the router fitting? I've had some luck in that size range finding make-do adapters from thin wall pvc fittings. Try browsing the Lowes/HD/Acme/you pick plumbing departments, especially the undersink fittings.
John Schaben
jschaben is offline
post #3 of 5 (permalink) Old 04-13-2011, 09:57 PM
Gíday Jase
Welcome to the router forum.
Thank you for joining us
For my Triton TRA001, I just use vacuum cleaner extension hose. other have suggested pool cleaner hose.
I have the router and also the Triton dust collector system and the hose works fine.
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 04-14-2011, 02:50 AM
paduke's Avatar
I used a flex hose for sump pump from home depot. It also is used on my chop saw and radial arm saw and trend line colts
paduke is offline
post #5 of 5 (permalink) Old 04-15-2011, 10:44 AM Thread Starter
Thanks for the replies and the welcome, fellas. Looks like I will grab my router and head to the Big Box Store (tm) and see what I can find to fit. Appreciate the feedback.
Jase is offline
dust guard on Triton rauch808 Table-mounted Routing 25 04-19-2011 07:54 AM
Dust control with Dovetail jig 603Country Jigs and Fixtures 6 12-06-2010 01:29 PM
Important information regarding TRITON harrysin Lobby 1 01-05-2010 08:08 PM
Dust Collection Question Tigerpaw Table-mounted Routing 17 04-16-2009 04:42 PM
Dust Right hose Fourleftpaws Tools and Woodworking 1 02-11-2009 12:38 AM
