Router bit bushing - Router Forums
post #1 of 10 (permalink) Old 04-17-2011, 08:22 AM Thread Starter
First Name: Dave
Default Router bit bushing
Id like to know If anyone can tell me where Id be able to find a 1 3/4" O.D. bearing with a 5/16" I.D . Im trying to set up a 1 7/8" slotting bit to cut a 1/16'' deep slot.
David2058 is offline
post #2 of 10 (permalink) Old 04-17-2011, 10:27 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Dave
Have a look at MLCS Woodworking Adaptor Bushings and Ball Bearing Guides and scroll down.
Cheers
Peter
istracpsboss is offline
post #3 of 10 (permalink) Old 04-17-2011, 10:50 AM
Ralph Barker's Avatar
First Name: Ralph
"Use The Fence, Luke, use The Fence." (apologies to Obiwan.)
If you have a router table, exposing just the 1/16" of the bit through the fence is easy. For hand-held, using an edge guide is another option.
- Ralph
Ralph Barker is offline
post #4 of 10 (permalink) Old 04-17-2011, 01:10 PM Thread Starter
First Name: Dave
I guess more information would be a help. Im trying to slot the frame on a fishing net and have to follow the cures and bends of the frame. Useing the fence isnt an option and a hand held is very shaky running on the thin edge of the frame. I appreciate all the thought and options, I just cant come up with the right solution.
post #5 of 10 (permalink) Old 04-17-2011, 01:56 PM
darrink's Avatar
First Name: Darrin
Send a message via Skype™ to darrink
Dave,
What thickness does the bearing need to be? Would it be possible to use a slotting bit with a smaller OD? How wide is the slot you are trying to cut? How about using a 1.75" OD bearing with the smallest ID and then use a bushing to get you down to 5/16" ID?
Darrin
darrink is offline
post #6 of 10 (permalink) Old 04-17-2011, 04:52 PM Thread Starter
First Name: Dave
Darrin, I think that would work, if I could find a 1.75" bearing. Im trying to cut a 1/16'' wide slot 1/16" deep. If I could find a slotting cutter with a smaller OD that would work too, but so far havent had any luck doing that. Thanks Dave
post #7 of 10 (permalink) Old 04-17-2011, 05:14 PM
RStaron's Avatar
First Name: Ron
Hi, Dave. Is there an industrial supply store near you, say a company called Motion Industries? they sell all sorts of bearings. They might get what you need. You are best to make a jig to hold the frame and steady the router. Just a thought.
A person can never have too many tools!
RStaron is offline
post #8 of 10 (permalink) Old 04-18-2011, 09:49 PM
darrink's Avatar
First Name: Darrin
Dave,
BOCA Bearings and VXB bearings both have 1.75" bearing. I think they are going to be too thick though.
Darrin
darrink is offline
post #9 of 10 (permalink) Old 04-19-2011, 09:59 AM
Dave, sometimes defining your task can be difficult. You mentioned the slot needs to be 1/16" deep; how wide does the slot need to be? How many of these nets are you planning on making? If this is a "one off" project the best answer might be different than if you plan to produce a large quantity. From what you have described it sounds like a Dremel 1" slot cutting bit with a collet adapter should be perfect for the job. You can easily make a collar to fit a standard guide bushing to gain your exact depth of cut. You can always make multiple passes to increase the depth or width of your cut.
PS: You can most likely get away using a composit wheel to make your cut with a small amount of burning. Here is a link to a $10 solution to your problem: http://www.harborfreight.com/80-piec...kit-97626.html
post #10 of 10 (permalink) Old 04-19-2011, 10:08 AM
http://www.routerforums.com/router-b...t-bearing.html
http://www.amazon.com/Dremel-670-Min...3066070&sr=1-6
Bit not centered in guide bushing RonH Guide Bushings and Templates 14 05-01-2009 12:41 PM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 06:50 PM
