Plunge Depth On A Triton TRA001/TRC001 3-1/4 - Router Forums
post #1 of 3 (permalink) Old 04-19-2011, 06:31 PM Thread Starter
AzViper's Avatar
First Name: Keith
Default Plunge Depth On A Triton TRA001/TRC001 3-1/4
Can some please tell be what the max. plunge working depth of the Triton TRA001/TRC001 3-1/4 Router. Thank You...
AzViper is offline
post #2 of 3 (permalink) Old 04-19-2011, 08:16 PM
Hello again, Welcome to this forum
One of the you tube videos said 68mm ~ 2-3/4", haven't found any specs myself but there are several here who have one. I suspect some will chime in soon
John Schaben
jschaben is offline
post #3 of 3 (permalink) Old 04-19-2011, 08:27 PM Thread Starter
AzViper's Avatar
First Name: Keith
Hi John,
Just getting as much info. I can to make the right decision. The more I read the more I keep returning back to the Triton 3-1/4 hp model. I started out reading reviews then I noticed nearly all the reviews were about the time the router was released in 2005. One would want to believe as you have state they have improved on their design. At $229.00 I beleive this is what I will buy...
AzViper is offline
setting depth for plunge router mag_rules General Routing 8 02-03-2010 12:58 PM
Milwaukee depth adj not accurate to plunge base eganders General Routing 3 11-06-2009 08:09 AM
triton 2 1/4 vs 3 1/4 lovoy7381 General Routing 1 09-16-2009 11:30 AM
Freud 2200E -- How do I set it up for a measured depth plunge cut? Ladd General Routing 8 11-12-2007 03:23 PM
Triton 3 1/4 HP plunge router $299 CDN CanuckBeaver The Bargain Bin 10 04-15-2006 10:41 AM
