First time with downcut spiral bit - complete failure - Router Forums
post #1 of 5 (permalink) Old 04-20-2011, 03:53 PM Thread Starter
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
Unhappy First time with downcut spiral bit - complete failure
I imported one of theseKatana downcut spiral flush trim bits and I wanted to use it to flush trim some solid wood edging on a jig I'm making. See first image. It's the 1/2" bit fitted to a Ryobi router and used hand-held.
Two problems;
1. I'm getting serious tear-out along the edge as I move along with the bit spinning. See image 2.
2. I'm also cutting into the veneer on the work piece which isn't that great and you can see this evidence in image 3 along with some of the pieces that split and broke off when I was routing.
So where did I go wrong? I tried up-cutting to stop the tear-out but this was less than successful and I didn't have control of the cut.
Any input is appreciated.
cagenuts is offline
post #2 of 5 (permalink) Old 04-20-2011, 04:18 PM
Guest
First Name: Regis
Hilton,
You will need more support for the router. Sandwich a thick, wide board (narrower than and longer than your work piece) between your work piece and a similar width board of exactly the same height as the one to be trimmed. Clamp the sandwich together and then clamp the middle board to the bench. You now have a a stable perch for the router. Trim the edge banding on the inside of the sandwich, unclamp and turn the workpiece around and trim the other side of the edge banding. Have the workpiece closest to you and route the inside edge from left to right. Hope this helps,
Regis
48394 is offline
post #3 of 5 (permalink) Old 04-21-2011, 04:27 AM
gav
Country: Croatia
First Name: Gavin
You might want to alter your feed direction and speed, could help.
As for cutting into the laminate, router tilt is most likely the problem, and the solution to that has been posted by Reg66.
You might also try adjusting the depth of cut so the bearing rides just beneath the edging. This way even if the router tilts, it won't be able to cut so much, if any of the laminate.
If those tips don't help, could also be that the bearing is slightly undersized. try putting a strip of masking tape across the laminate where the bearing rides.
gav is offline
post #4 of 5 (permalink) Old 04-21-2011, 06:41 AM
First Name: del
Two problems;
I belive just a Flush Trim Router Bit would work better ? not the down spiral bit ? The flush trim bit would cut like flat on the wood and not try and work the wood down . May cause the wood to tare off ?? Like trying to cut the wood down? my 2 cents
del schisler
port st. lucie, florida
del schisler is offline
post #5 of 5 (permalink) Old 04-21-2011, 06:54 AM Thread Starter
cagenuts's Avatar
First Name: Hilton
Thanks Regis and Gavin for the replies.
I essentially have a 2nd board next the main board but it's not the same height, just clamped to the correct height.
One thing I did notice is that even though I put a straight edge over the top to make sure I had a level playing field, when I tested the cut (without the power on) there was definite wobble on the router. It's very strange as the router base is brand new and very flat (Milescraft) but perhaps I need a 2nd board with a thicker top to balance the router base on. I used a piece of 16mm melamine coated particle board for this.
I like the idea of just plunging the bit to the exact required depth as I was certainly cutting way below that. In terms of the splintering it seemed to happen in the same spot in the wood both sides so maybe it's just not great wood to start with.
It's a bit disheartening when you try something and it fails miserably.
Enjoy the Easter weekend everyone.
cagenuts is offline
Removing material with an up cut spiral bit? Nickbee Router Bits - Types and Usage 10 12-02-2007 03:02 PM
intro splitcanoe New Member Introductions 8 02-17-2007 06:40 PM
Sharpen a spiral bit fade2black Router Bits - Types and Usage 6 01-05-2006 11:04 AM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 06:50 PM
Bit problem - using spiral bit in a table Matt Router Bits - Types and Usage 4 11-23-2004 08:02 PM
