Daisy pin router-smaller pins needed - Router Forums
post #1 of 8 (permalink) Old 04-24-2011, 09:29 AM Thread Starter
Default Daisy pin router-smaller pins needed
I purchased a daisy pin router to cut out small wood pieces for craft projects. The smallest pin that comes with the set is 1/4" but I need to cutout a smaller area of 1/8" between some sections? Does any one know if there is a smaller pin available, I have been to product site but no luck. Since the pins screw into the overhead arm I wasn't sure if one could be made easily or not either.
Coedog is offline
post #2 of 8 (permalink) Old 04-24-2011, 09:53 AM
Hi
" smaller pin available " = not that I know about but you can make your own easy,just stop by a ACE hardware and pick some brass bolts or brass rod, cut off the head and chuck the stud in your drill motor and grind it down to 1/8",,easy stuff..
You can also get a rod coupling nuts at ACE.
post #3 of 8 (permalink) Old 04-24-2011, 04:16 PM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 8 (permalink) Old 04-24-2011, 07:06 PM
G'day
Welcome to the router forum.
Sydney, Australia
jw2170 is offline
post #5 of 8 (permalink) Old 04-28-2011, 07:40 AM Thread Starter
Are you suggesting brass because it is easier to grind down? We did look at a couple of near by hardware stores but the size needed is metric so it is hard to find in brass. We did pick up a couple in stainless steel but I suspect that will difficult to grind. Also, we don't have grinder but we do have some grinding wheels that fit on a drill. Any tips for the grinding process?
Coedog is offline
post #6 of 8 (permalink) Old 04-28-2011, 08:48 AM
Hi
" metric " = ?, you may want to check it one more time..(5/16-18 the norm)
Brass is soft and stainless is hard to rework, (the norm 18.8 ,304 stainless steel)
grinder wheel on the drill is going to be hard to do but with some work it can be done, I would suggest clamping the drill down on to a 2 x 4 " L" block and drill a hole in the stock for the stud, that will let it just fit in and turn the stud with a pair of vise grips. it's going to get very hot...have some water near by
Good Luck
post #7 of 8 (permalink) Old 04-28-2011, 04:34 PM Thread Starter
Seemed odd to us too but we needed a bolt that was a M8-1.25 We took it with us and had to try several before realizing that the metric one was the only one that fit. I think they said it was a small or narrow thread size also.
We were thinking we would bolt the the griding wheel down and use the bolt/rod in the drill method you mentioned before.
Coedog is offline
post #8 of 8 (permalink) Old 04-28-2011, 06:28 PM
Hi
Just one more way,,pickup a 1/8" steel dowel pin and Drill a hole, to just press/tap in the pin.
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Router Table Pin Router Tim in Delaware Table-mounted Routing 7 03-08-2010 02:55 AM
building a Pin Router dane5547 General Routing 36 08-13-2009 02:58 AM
