Adjustable Arc or Circle Jig Plans (Needed) - Router Forums
post #1 of 14 (permalink) Old 04-24-2011, 11:21 PM Thread Starter
AzViper's Avatar
First Name: Keith
Default Adjustable Arc or Circle Jig Plans (Needed)
Looking for a arc jig that I can build that is not a 1/4 piece of wood with a nail use as a pivot point. I have a slew of jig I use for making poker tables but here of late I have been getting orders for sizes I do not have jigs for. I have used the nail thing and it works but its not all that accurate.
I was thinking of ataching the pivot point with carpet tape and having an adjustable arm of 25 inches so that I can use a full sheet of ply to make the tables from or smaller. Would like to have a bearing pivot point of 1/4 inch. I can invision what I want but was hoping someone has built a hi-tech jig...
AzViper is offline
post #2 of 14 (permalink) Old 04-25-2011, 09:50 AM
CharleyL's Avatar
First Name: Charley
The best circle/arc cutting jigs that I've used are made by Jasper. There are 3 models for cutting hole or arc sizes in increments ranging from 1/2" to about 36" radius.
I've used all three sizes at work, but the one that I have (400J) is the smallest size. If you follow the simple instructions it will cut very precise holes using a router and a 1/4 spiral router bit.
A Google search for "Jasper Router Jig" brings up the following Amazon page. All three sizes of these jigs are shown with the one that I have being the 400J in the main photo. Amazon.com: Jasper 400J Model 400 Router Circle Cutting Jig: Home Improvement
They aren't very complicated, so once you have seen one It would be relatively easy to make a similar design for yourself. I like the Jasper jigs because of the calibrated holes that allow for quick setting of the desired hole/circle size. Doing this hole pattern accurately in a home made jig would be difficult to get right.
Charley
CharleyL is offline
post #3 of 14 (permalink) Old 04-25-2011, 10:11 AM
Hi
I also like the Jasper jigs but when it comes to the big cir. jig the Rockler is the best one I have (2 1/2" to 52" ), no bearing needed just a brass guide to make it hi tech. just drop the router on the jig and cut the cir. out quick and easy..and it always dead on..
See the picture below for the brass guide setup put more in my uploads.
Rockler Ellipse/Circle Router Jig - Rockler Woodworking Tools
NOTE,, the Rockler jig is on sale ,the norm is 99.oo why not get one jig for both type of jobs..
Note++++ with the Rockler jig you don't need to put in the nasty pivot hole in the table top stock, just stick a block of wood down with DSCT and drill in a small hole for the pivot point.
post #4 of 14 (permalink) Old 04-25-2011, 10:15 AM
RJM60's Avatar
First Name: Robert
The circle jigs that everyone on this forum makes seem to work fine and are very accurate. Try going up to 1/2" stock and a 1/4" pivot. I use a 1/4-20 bolt and cut off the threads (i.e. buy one long enough so that the unthreaded portion protrudes at least a 1/2 inch). You don't need a bearing for this since each time you use it, you make a new hole. For the jig, use a 15/64 drill bit for the pivot hole and press the bolt thru. You may need to ream out the hole a bit but if you have a letter index, a C bit would be perfect. This will hold the pivot tight in the jig.
I've heard of carpet tape (double sioded tape) used for various purposes and it will probably work here as well if you make the base large enough. You still don't need a bearing but since you're using the same pivot hole over and over, you may need to re-drill the base after a number of uses.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #5 of 14 (permalink) Old 04-25-2011, 10:16 AM
Hi - Plus one on the Jasper jig series. Sounds like you would like the model 300
Amazon.com: Jasper 300J Model 300 Router Circle Cutting Jig: Home Improvement
7" to 52 3/4" diameters in 1/4" increments, calibrated for a 1/2" router bit.
Take a close look at Bj's recommendation also. Downside to the Jasper is it still needs a pivot hole someplace. The Rockler jigs pivot can be taped or glued down.
John Schaben
jschaben is offline
post #6 of 14 (permalink) Old 04-25-2011, 04:15 PM Thread Starter
AzViper's Avatar
First Name: Keith
The Rockler Elliptical Router jig would be ideal if it would allow to cut out larger elliptical’s. It would be great to offer a poker table that was nearly 95 inches long and 44 inches wide. Because of the slow arc on each side this would all more room at each seat for each player. Anybody have any ideas? I would love to offer and have and own a elliptical Poker Table of this size.
AzViper is offline
post #7 of 14 (permalink) Old 04-25-2011, 05:22 PM
Hi
No big deal to add a extension to the Rockler jig once you have the basic jig..or to made your own cross plate for the real big Elliptical jig..all that's needed is a good dovetail bit and some hardwood stock.
post #8 of 14 (permalink) Old 04-25-2011, 05:38 PM Thread Starter
AzViper's Avatar
First Name: Keith
Hi
Your correct... I know Rockler is offering a larger cross plate as well. I could make another arm that is extended to cover an entire sheet of ply. Do you know what the Rockler system is made from?
AzViper is offline
post #9 of 14 (permalink) Old 04-25-2011, 05:43 PM
HI
1/4" thick phenolic
post #10 of 14 (permalink) Old 04-25-2011, 06:18 PM
Hi - Might be able to make one. Seems like the size of the base would control the axis by allowing further travel along the axis. I don't know enough about them yet to conjure up any definitive plan.
Also could just make up a template with a 22" radius circle, cut in half and "stretched" with straight pieces. Thing with an elipse is that the greater the difference between the major and the minor axis the more "pointy" the ends get.
Just some rambling thoughts from a wandering mind.
John Schaben
jschaben is offline
Router Adjustable Dado Jig Barry_White Jigs and Fixtures 18 07-20-2010 03:36 PM
