Fix my router - Router Forums
post #1 of 8 (permalink) Old 04-27-2011, 02:32 PM Thread Starter
Default Fix my router
i HAVE A POTER CABLE 3 1/4 HP MODEL 75192 TYPE 1
I HAVE BEEN WAITING FOR WEEKS TO GET A NEW SOFT START BUT STILL NOT IN
AND I HAVE TO FINISH SOME RAISED PANEL DOORS FOR A CUSTOMER
THE SERVICE CENTER SAID I CAN BY PASS THE SWITCH TILL THE PART COMES IN
BUT I CAN'T FIND A WIRING DIAGRAM
IT LOOKS PRETTY SIMPLE
I HAVE THE 2 BLACK WIRES AND 1 BLUE GOING INTO THE SWITCH
WHICH ONES DO I CONNECT
CAN YOU HELP
boatnik is offline
post #2 of 8 (permalink) Old 04-27-2011, 03:21 PM
Hi
Try the link below and I'm sure you will get the info you need.
http://forums.ereplacementparts.com/
http://forums.ereplacementparts.com/...searchid=56653
CAN YOU HELP
post #3 of 8 (permalink) Old 04-27-2011, 07:30 PM
RJM60's Avatar
First Name: Robert
Probably the black ones.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #4 of 8 (permalink) Old 04-28-2011, 01:45 PM
First Name: Al
Hi Bob. I would talk to the service centre again and ask them. I'm familiar with electrical circuits but new to routers so I would not advise you by just guessing at what to do. Oldrusty.
oldrusty is offline
post #5 of 8 (permalink) Old 04-28-2011, 05:50 PM
RJM60's Avatar
First Name: Robert
Not entirely a guess. It's pretty easy to figure out but if you have to ask, I guess you should wait for the switch.
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #6 of 8 (permalink) Old 04-28-2011, 06:26 PM
Cassandra's Avatar
First Name: Cassandra
Hi boatnik:
If you want to remove the soft-start controller from the circuit, disconnect the two black wires from the soft-start controller and then connect the two black wires together. Then insulate the joined black wires. This procedure will convert your router into a full-speed-only router, suitable for use with external speed controllers.
Be forewarned that removing the soft-start controller from the high-power router will likely cause large inrush currents at starting, unless one is using the external speed controller.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #7 of 8 (permalink) Old 04-29-2011, 01:08 AM
BigJimAK's Avatar
...and large inrush will make the router try to spin on startup.
BigJimAK is offline
post #8 of 8 (permalink) Old 05-02-2011, 12:47 AM Thread Starter
thanks guys for all your responces
I already pulled the 2 black wires out and put then together and nothing happened thats why question to you guys
how ever i did get the router to kick on
I have also read allot about this router and it seams to me my 12 year old router might be better off waiting for the new part
Greg.
boatnik is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Sears Plunge Router Model 315.275110 Wally99 Table-mounted Routing 3 12-24-2008 06:39 AM
