Replacement bearings for Bosch 1617EVS - Router Forums
post #1 of 3 (permalink) Old 04-28-2011, 08:45 PM Thread Starter
First Name: Mark
Default Replacement bearings for Bosch 1617EVS
I have a Bosch 1617EVS router that I use as the spindle on my CNC mill. I need to replace a bearing and I figure that I might as well replace them both while I'm at it. Since low run-out is extremely important for a CNC router, I want to replace the bearings with the highest quality replacements I can. I'm no expert on bearings, but I hear this might involve ceramic bearings (whatever they are). Since I can't specify these things on my own, could someone please recommend some replacements (including part numbers) for me?
Thanks for your help,
Mark
mickelsen is offline
post #2 of 3 (permalink) Old 04-28-2011, 09:16 PM
G’day Mark
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #3 of 3 (permalink) Old 04-29-2011, 07:28 AM
Mark, there is no need to vary from the factory bearings. Bosch has been involved in CNC routing for many years in the optical industry. The Bosch 1617 family of routers are industrial quality and will perform well as long as you blow out any accumulated dust with compresed air. I suggest you stick with factory parts.
Babbit bearings Jack Wilson Lobby 3 04-09-2011 09:27 PM
Bosch 1617EVS bearing problems Gunga New Member Introductions 2 02-05-2011 08:21 AM
How are the bearings in your router mike black General Routing 8 04-12-2010 10:03 PM
burnt bearings allthunbs General Routing 4 09-12-2009 08:57 AM
