Router guides for Skil - Router Forums
post #1 of 5 (permalink) Old 04-29-2011, 11:30 PM Thread Starter
Default Router guides for Skil
I bought a Milescraft 1211 Base Plate Metal-Nose Bushing Set for Routers.
It saids it is good for Skil routers. I can't find holes compatible with my router.
Can I drill holes into the base to match my router holes or will it crack?
jschiavone is offline
post #2 of 5 (permalink) Old 04-29-2011, 11:42 PM
xplorx4's Avatar
First Name: Jerry
Greetings John and welcome to the router forums, we are glad to have you join us.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 5 (permalink) Old 04-30-2011, 01:35 AM
G'day John
Welcome to the router forum.
Thank you for joining us.
It should not crack - some members use that plate and have drilled for their own routers
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 04-30-2011, 06:28 AM
Hi John - Welcome to the forum
I can't imagine not having a pattern in there that matches. Those are almost a study in too many holes. Remove the old plate, put the 5/16" bushing in the milescraft plate and either the centering pin (if you have the 1/2" collet) or a 1/4" bit (either router bit or drill bit, doesn't matter here) in the collet. Drop the Milescraft plate on the pin/bit and rotate it around. Some of the "matches" may actually be slots. Good luck
John Schaben
jschaben is offline
post #5 of 5 (permalink) Old 04-30-2011, 07:43 AM
Hi John
It will fit you don't need to use all the holes in the router base you just need two of them to hold the plate in place, the one below is on a T4 router.
You can drill new holes but I don't think you will need to.
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Matching bushing guides with a Bosch router / Craftsman Pro template flyingHigh General Routing 1 01-25-2010 08:56 PM
Router workshops template tom Guide Bushings and Templates 4 09-01-2008 10:41 AM
Hello from Down Under Hoppoz New Member Introductions 50 02-01-2007 12:40 AM
