insert for Freud 1700 router - Router Forums
post #1 of 4 (permalink) Old 05-11-2011, 03:52 PM Thread Starter
Country: Bermuda
First Name: Gavin
Default insert for Freud 1700 router
Hello - I purchased recently a freud 5000 router table which came with a Freud 1700 router - problem the insert plate does not line up with the 1700 router. Have searched around Google trying to find one but no luck...any suggestions please
Thanks.
floatswitch is offline
post #2 of 4 (permalink) Old 05-11-2011, 04:06 PM
Thanks.
Hi Gavin - Welcome to the forum
I haven't seen to many plates predrilled for the 1700. That table was orginally marketed with the Freud 3000 so it is probably drilled for that one, if it's drilled.
Rockler has one in their "group B" plates but it is 8 1/4' by 11 3/4" so you need to make sure it fits the table.
Alternatively, you can redrill the plate you have using the plastic subbase plate as a template. You would end up with a couple of extra holes but that shouldn't hurt anything.
Good Luck
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 05-11-2011, 06:25 PM
http://www.routerforums.com/freud/78...-template.html
Thanks.
post #4 of 4 (permalink) Old 06-11-2011, 11:07 AM
First Name: Dave
Thanks.
If you find on please let me know also Davehest
davehest is offline
Mounting router to table insert Slow Willie Table-mounted Routing 4 01-09-2011 03:58 PM
router insert plate lindasuderman General Routing 4 04-07-2010 06:05 AM
Router table insert cbrittain Table-mounted Routing 7 06-01-2009 09:22 AM
Homemade Router Table Insert Question? deck99 Jigs and Fixtures 3 07-03-2006 11:56 PM
