Cam questions - Router Forums
post #1 of 8 (permalink) Old 05-16-2011, 08:20 PM Thread Starter
Marco's Avatar
Default Cam questions
Ok A few questions to clear my mind about cams in the cam board.
1) Your Cams are made out of large Oak Dowels?
2) 1" round or larger?
3) How thick are the cams 1/2"?
4) Machine bolts with allen heads?
5) Holes, 2 that are off center and counter sunk?
6) With the holes off center it creates pressure into the material when tightening the bolt?
7) 1 cam on each side of the material will hold it down?
8) The cam board has squared straight boards on each side for the ski handle to run against?
ďItís not a mistake, itís a design featureĒ
Marco is offline
post #2 of 8 (permalink) Old 05-17-2011, 12:55 AM
Marco, there is no right or wrong sizes for the cams. The cams should be a bit shorter than the material you are working with. Most people use wood screws to attach the cams, I would suggest square drive screws. (Robertson for our Canadian members) Keep in mind there is no one size of cam board that will handle all jobs. You will often need to build a new box to fit your project. The cams are for holding in position, not holding down. Ski jigs are usually wider than the cam board so you can rout with out interference.
post #3 of 8 (permalink) Old 05-17-2011, 09:21 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
1) Any hardwood
2) 1 1/4" is better
3) 1/2" to 3/4" is fine
4) I use machine screws with countersunk heads into T nuts
5) One hole only required
6) Not really, twist the cam whilst tightening the screw
7) Eight cams are required to ensure zero movement of the work-piece
8) Running the skis against the camboard is only really for slots and grooves.
These photographs taken from several previous projects give an idea of how I secure the workpiece and use the skis.
Harry
harrysin is offline
post #4 of 8 (permalink) Old 05-17-2011, 02:00 PM
Hi Jim, Here's a picture of my last one. 2 1/2" between the holes and 2-3/8" cams, although I will likely make some more cams in different sizes. Base is 3/4" furniture grade (at least Home Depots idea of furniture grade) plywood and the cams are 1/2" plywood. This one uses 10-24 combination head (phillips + straight drive). Button head cap screws are expensive for me as I have to mail order them. They really don't need torqued down all that tight anyway.
Point is, no need to overthink the thing, just need to hold the workpiece firmly without it getting in the way.
John Schaben
jschaben is offline
post #5 of 8 (permalink) Old 05-17-2011, 04:13 PM Thread Starter
Marco's Avatar
Thanks to all for the input and answers. Trying to get all the info by the sites "Search Button" has been time consuming and a little frustrating. Good Lord willing, I should have a board or two working for me in no time as I have all the pieces to my self made Cam Board puzzle.
John you are absolutely right in observing my bad habit of "over thinking" it when there is no need,
Marco is offline
post #6 of 8 (permalink) Old 05-18-2011, 07:26 PM Thread Starter
Marco's Avatar
Well finally got my Cam Board up and running and ran through a learning curve in the process.
Image 1 is of the Cam Board itself. 3/4 MDF with T-tracks
Image 2 is the cams. 3" round 1/2" inch plywood with 1/4"- 20 anchor bolts shortened. The top of the cam is countersunk 3/4" wide at the bolt opening so a nut driver or socket can access the nut.
I had the MDF and the t-track bit and the 3"round 1/2" Plywood and anchor bolts were headed for the dumpster at work so a FREE Cam Board is the reason for the differences in material. I did buy some t-track nuts and used them but didn't like them because when tightening them down after a few times, the bolt would eventually sink to the bottom of the t-track causing it to stick.
What I learned about using the router as a planer with the help of a Cam Board to hold the material in place.
1) Look at the wood first for cupping etc. and work at flattening one side then flip it. A cupped board can and will give at the corners causing to gouge the wood.
2) Just take a little bit at a time off! Give yourself plenty of time to do it as setting everything up and doing it right is going to eat up the minutes.
3) Plane your wood down before cutting it into pieces needed for your project. Thinning each piece seperately is time consuming, and more difficult to get the same thickness.
4) Clamping 2 pieces side by side with cams is not a good idea as they want to pop up where they join
5) Using a plunge router makes it easier to get your final thickness
6) You need to have your Router Ski Handles cut to accomodate the handles on your router
After lessons learned I was able to get the thickness I wanted and smoothed it all out with a belt sander in picture 3
Thanks to all for making posts over the years about cam boards and router skis as it took a lot of "Searching", reading and asking of questions on this site to get the information needed to get both completed
Marco is offline
post #7 of 8 (permalink) Old 05-18-2011, 08:03 PM
Looks good Jim!
Hadn't thought of using t-tracks but I can see some advantages in being able to relocate the cams quickly. MDF will likely wear out on you after awhile but like you said, price was right.
John Schaben
jschaben is offline
post #8 of 8 (permalink) Old 05-18-2011, 09:54 PM
Hi JIm
Nice job,,I will say cams are not always the best way, wedges work very well to hold the wood in place and with a pin nail or two sticking out of the wedge it will keep the stock from moving up or down..
Two cam board issues SE18 General Routing 18 09-22-2013 12:18 AM
Jasper Model 274 Random Noob Questions nwsalmon Jigs and Fixtures 3 03-06-2011 09:00 AM
No questions in this section! Mark Router Reference 0 06-08-2008 12:59 AM
Cam Design Guidelines rstermer Jigs and Fixtures 6 05-27-2008 04:37 PM
Crossword Puzzle with BJ's questions BobandRick Site Help and Suggestions 0 02-01-2007 01:16 PM
