can't change the bit - Router Forums
post #1 of 3 (permalink) Old 05-22-2011, 11:34 AM Thread Starter
First Name: momofniel
Default can't change the bit
can't change the bit on a 315.17381
momofniel is offline
post #2 of 3 (permalink) Old 05-22-2011, 11:44 AM
mpbc48's Avatar
Check out;
http://www.routerforums.com/craftsma...or-manual.html
in the manuals section of the routerforums.
Page 3, item 4 references removing cutters. Sometimes you have to totally remove the collet to "force" the bit out. If this is the case, you may have a damaged collet.
It is not recommended to put lubricant on the collet to aid future removal of bits.
hth
You think I'm crazy? Wait till you meet my imaginary friends.
mpbc48 is offline
post #3 of 3 (permalink) Old 05-23-2011, 06:16 PM
dutchman 46's Avatar
First Name: Howard
Please give us a bit of information! What router, type of bit, and what You have dome to loosen the bit. Remember: Do not tighten the bit when the bit is bottomed out.Also: When removing the bit, use a piece of dense wood to tap on the shaft of the bit. The collar can be wedged in the cap, and tapping the shaft will help release it. Then replacing a bit, pull the bottomed out bit back about 1/8 inch before tightening the collet completely! Do not lube the shaft to loosen a bit. If it is not cleaned out and all lube is not out, the bit may move and be thrown into the shop, and they can do a great amount of damage to You, a Friend, or Your project! Welcome to the forum, We are glad that You are here. I do not want to sound like I am all work, but feel that a great many people could be hurt with a bit!
John 3:16
Last edited by dutchman 46; 05-23-2011 at 06:19 PM. Reason: Needed to be nice :) :) :O
dutchman 46 is offline
How to change router bit Dan S. Tools and Woodworking 5 11-15-2010 01:55 PM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 06:50 PM
bit speeds, something to think about reible Router Bits - Types and Usage 0 10-19-2004 09:20 PM
RouterForums Amateur Night Rabbet bit Tables reible Router Bits - Types and Usage 1 10-10-2004 09:03 PM
