Bosch pof 1200 AE router question lplease.. - Router Forums
post #1 of 10 (permalink) Old 05-23-2011, 04:10 PM Thread Starter
Default Bosch pof 1200 AE router question lplease..
Hi guys
bought my first router today and have a few questions if I may...it comes with 3 collets 6mm 8mm and 1 quarter inch..and a sds device...
my probably daft questions are what is the SDS device for and will the router only take quarter inch bits and what are the 6mm and 8 mm collets for...sorry if these seem silly questions but never used a router before..
thecoder is offline
post #2 of 10 (permalink) Old 05-23-2011, 04:57 PM
crazycol's Avatar
First Name: colin
hiya dave, the sds function on your router enables the user to insert template guide bushes with a bayonet lock without the need for additional tools. maybe a gimmick but if it works great then fine. the 6mm and 8mm colletts are for the different dia shank bits you can use.
parachute for sale one red stain
crazycol is offline
post #3 of 10 (permalink) Old 05-24-2011, 04:06 AM Thread Starter
Many thanks Colin....picked up a very cheap second hand bosch from family friend so all i need to do now is figure out how to use it ....
thecoder is offline
post #4 of 10 (permalink) Old 05-24-2011, 04:08 AM Thread Starter
Originally Posted by thecoder View Post
Hi guys
Many thanks Colin bought a second hand router from family friend so all I need to do now is figure out how to use the thing lol.
thanks for the help.
dave
thecoder is offline
post #5 of 10 (permalink) Old 07-24-2011, 04:32 AM
Country: Italy
First Name: riccardo
hello, i have a question myself: is it possible to have this router switched permanently on? i mean, not with some sort of self made locking mechanism, does it have this kind of function already built in?
i'm thinking of using it with a router table i'll make, but apparently all i could figure out is operating it manually with the trigger switch
any help?
blackritchie8 is offline
post #6 of 10 (permalink) Old 07-24-2011, 08:58 AM
Welcome to the forums guys. Riccardo, when this type of router is used in a table it is common to set the trigger lock and control the power by using an external switched power source. Always unplug your router when making set up's or bit changes.
Despite a slight difference in appearance the functions are the same as the Bosch 1617EVS you will see in many threads here. The SDS adapter allows the use of two piece brass Porter Cable style guide bushings which I highly recommend. While the steel Bosch guide bushings work fine for most uses brass is a better choice since it will not nick your cutters should they hit each other during set ups. There are many fine routers but Bosch is my choice.
post #7 of 10 (permalink) Old 07-24-2011, 01:35 PM
Country: Italy
thank you for your answer. let me see if i got it, i basically have to lock its switch on with someting and then use a switch to supply power or shut it down when i don't use it?
post #8 of 10 (permalink) Old 12-08-2013, 01:15 PM
First Name: Geoffrey
I've been told that the power switch can't be locked on.
I find this very very surprising.
it it true?
geoffreyx is offline
post #9 of 10 (permalink) Old 12-09-2013, 06:21 PM
First Name: Al
A simple way to lock the trigger is to use a small tyrap. It can be easily removed for hand held routing Plug the router into a combination switch/plug mounted on the front of your router table. Preferably a paddle switch. They are readily available. Oldrusty.
oldrusty is offline
post #10 of 10 (permalink) Old 12-16-2013, 04:29 AM
Geoffrey
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Bosch RA 1180 Router Table & Skil Router sjrhynard Starting Off 4 01-15-2010 05:10 PM
Bosch Thread Router Template Adapter/Porter Cable megreene Router Bits - Types and Usage 4 12-26-2008 11:36 PM
