routing end grain hardwood - Router Forums
post #1 of 6 (permalink) Old 05-24-2011, 09:24 PM Thread Starter
Default routing end grain hardwood
I am needing to 'straighten' the ends of some hardwood flooring I installed a year ago so I can start a new install tight to the older one. Any suggestions as to the best way to do this? I am considering a template bit, 3/4" diam. 1 1/4" long with a 1/2" shank. I plan to take numerous passes to ensure I don't get a lot of tearout. any other thoughts fomr anyone? Thanks
JRB The Handyman is offline
post #2 of 6 (permalink) Old 05-24-2011, 09:31 PM
mpbc48's Avatar
Hi Jim,
I suggest using a backerboard to minimize/eliminate tearout. You won't need multiple passes either.
You think I'm crazy? Wait till you meet my imaginary friends.
mpbc48 is offline
post #3 of 6 (permalink) Old 05-24-2011, 09:48 PM
Hi Jim
I would suggest a over lap cut with a good jig saw and a good Bosch blade,just over lap the boards and cut them both at the same time, if you cut them in a "S " they still will line up just right and tight..(good side down when you cut them)
post #4 of 6 (permalink) Old 05-24-2011, 09:50 PM
Honored Member
First Name: pat
Edge or disk sander.
Quillman is offline
post #5 of 6 (permalink) Old 05-25-2011, 03:13 AM
Jim, since your flooring is already installed your best bet is to make a simple guide strip for the router to ride on. I suggest using 1/4" tempered hardboard for this and following the edge with a guide bushing. Fasten it down with double sided carpet tape, the cheapest you can find since it only needs to hold for a few minutes. This assures you will have a clean finished edge.
post #6 of 6 (permalink) Old 05-25-2011, 06:49 AM
crazycol's Avatar
First Name: colin
thats the way i would go too. cheaper and easier.
parachute for sale one red stain
crazycol is offline
Ski question os smoothing end grain, bit, speed, etc TanOak Portable Routing 4 11-07-2010 09:03 AM
Raised Panel End Grain Question. AlanSweet The Finishing Touch 6 05-17-2010 08:32 PM
Routing end grain jschaben General Routing 10 07-17-2009 02:17 AM
Tear out when routing end grain cuttin board RealCom Table-mounted Routing 8 07-10-2009 09:33 AM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 12:24 PM
