90 degree cut - Router Forums
post #1 of 4 (permalink) Old 05-25-2011, 04:23 PM Thread Starter
First Name: David
Default 90 degree cut
Hey everyone, I'm a brand new carpenter. I found this treasure trove of information on this forum a little while ago but I still can't find what I'm looking for. I was wondering what router bit or technique I need it order to make right (or other perfect) angles with my router. I'm trying to inlay some trimming for decoration on a table and I need to make a square "valley" so the inlay is flush with the top.
David
4337Fortson is offline
post #2 of 4 (permalink) Old 05-25-2011, 08:23 PM
David
Hi David - Welcome to the forum
I assume you are talking about the bottom of the relieved part being square with the sides? Most use a spiral bit for making inlays although all the straight bits I know of will leave the bottom square also, just not all will plunge cut.
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 05-25-2011, 11:31 PM
papawd's Avatar
First Name: warren
Welcome
papawd is offline
post #4 of 4 (permalink) Old 05-26-2011, 07:55 AM
Solid Brass Router Inlay Kit
http://manuals.harborfreight.com/man...9999/99552.pdf
http://store.workshopsupply.com/cata...40e1b2c628cbfc
Table top display cse. derek willis Show N' Tell 16 04-13-2014 06:31 AM
slidng on the rods allthunbs General Routing 11 04-07-2011 05:26 AM
68 degree cut clayton borger General Routing 4 01-21-2011 05:20 PM
Up Cut... Down Cut... Joe Lyddon Router Bits - Types and Usage 2 09-10-2006 06:21 PM
Welcome to "Show N' Tell" Mark Show N' Tell 0 08-17-2005 04:55 PM
