Setup of rail and stile bits - Router Forums
post #1 of 6 (permalink) Old 05-30-2011, 08:39 AM Thread Starter
Country: South Africa
First Name: Mark
Default Setup of rail and stile bits
I am trying to setup my rail and stile router bits. They have come with shimes for this job, but I am looking for a procedure since I don't know where to start-which bit do I do first.
markristow is offline
post #2 of 6 (permalink) Old 05-30-2011, 09:13 AM
Hi Mark
The video below will help you...>>> get the job done
MLCS Rail and Stile Carbide Tipped Router Bits 1
post #3 of 6 (permalink) Old 05-30-2011, 10:52 AM
Hi, Mark
I start with the cope cut on the ends of the rails first (ends of horizontal pieces on top & bottom). Then machine the profile all four pieces with the stile bit.
What brand bits do you have?
http://www.sommerfeldtools.com/somme...log/page27.pdf
http://www.mlcswoodworking.com/shops...lstile0911.pdf
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #4 of 6 (permalink) Old 06-06-2011, 10:49 AM Thread Starter
First Name: Mark
Thanks for the feedback. I don't quite know what brand of bit I have as they have no branding on them. The main problem is that the profiles do not fit into each other and I need to add or subtract shims. I just can't get it right, maybe I am not starting in the right place. The other thing I noticed is that the bits have different diameter bearings on them. I this correct?
post #5 of 6 (permalink) Old 06-06-2011, 11:15 AM
Hi Mark
" different diameter bearings on them. I this correct? " = not the norm.
If it's a New set take it back to the store and have them replace it with a set that will fit..
post #6 of 6 (permalink) Old 06-14-2011, 04:54 AM Thread Starter
First Name: Mark
I purchased the correct size bearing so that problem is solved. It just seems that the ogee profile of the two cutters is not the same and I can't get them to match. I am suspecting that the ogee cutters are not a matched pair. I can't take this back to the store since I bought it about a year ago and only got around to using them now.
stile and rail bits, torence20 Table-mounted Routing 11 02-08-2010 09:03 AM
Bits to use for a square or plain rail and stile? azw Router Bits - Types and Usage 6 01-17-2010 03:02 PM
Stile and Rail bits, whiteside or rockler whtteg Router Bits - Types and Usage 6 07-31-2009 06:53 AM
Bosch Ogee Rail and Stile Bit Set setup? gxbluewave Table-mounted Routing 1 01-07-2008 09:45 PM
Stile and Rail setup? fitz Jigs and Fixtures 1 03-26-2005 07:53 AM
