Router Jumps - Router Forums
post #1 of 10 (permalink) Old 05-30-2011, 05:40 PM Thread Starter
Default Router Jumps
I am attempting to make a mission style bed. The foot board calls for me to make twenty mortises along two 5 inch wide boards. I then glue the boards together. The slats are then put down the mortise. I make cuts two inches wide and ten inches long using a straight cut router bit. The first several cuts are fine but at some point the the router seems to jump. It tears the sides of the cuts and sometimes tears out the wood. I am using red oak. I just sent the router bit out to be sharpened. Is the problem a dull router bit, messed up wood grain or just bad technique?
windrider is offline
post #2 of 10 (permalink) Old 05-30-2011, 05:53 PM
N/A, the trick is to rout a dado the length of the boards and cut some spacers to fill the area between the slats. Once it is glued up you wont even notice.
post #3 of 10 (permalink) Old 05-30-2011, 06:00 PM
Honored Member
First Name: pat
I suspect, with a stick that big, you're hand routing?
And if you are, 2 edge guides (one on each side of the work) will trap the router on the stick. Now, with you in control (not the router controlling you) the cutter won't smash into the mortice wall.
Quillman is offline
post #4 of 10 (permalink) Old 05-30-2011, 06:26 PM
Hi
" using a straight cut router bit " = it sounds like you are using the wrong type of router bit, you need to use a bit that will lift the chips out of the slot and use your vac pickup tube on your router to suck the chips out and away..
Most all straight router bits will just let the chips go around and around and at some point the router will jump over them..
MLCS solid carbide router bits
post #5 of 10 (permalink) Old 05-31-2011, 04:39 AM
derek willis's Avatar
First Name: Derek
They,ve said it all, but, the industrial way is what Mike suggested and also the way I have done it.
Derek
derek willis is offline
post #6 of 10 (permalink) Old 05-31-2011, 03:33 PM
Phil P's Avatar
First Name: Phil
Originally Posted by derek willis View Post
They,ve said it all, but, the industrial way is what Mike suggested and also the ay I have done it.
Derek
I've never seen it done that way in industry, far too much cleaning up for volume production. Thos guys use Rye or Bacchi multi slot mortisers or Maka muklti-head mortisers. In small batch work I'd do it using a hand router, straight cutter, slot jig (a saddle-style jig gives much better support for the base of the router) , guide bush and vacuum to clear the waste produced - or alternatively on a square chisel mortiser
Regards
Phil
Phil P is offline
post #7 of 10 (permalink) Old 05-31-2011, 04:59 PM Thread Starter
Thanks for the info. All are true. (Hand held router and long cuts). THe "chips" did pile up quickly. Will get a up spirl bit and stronger side bar guides. Thanks
post #8 of 10 (permalink) Old 05-31-2011, 10:12 PM
N/A, this method is recommended by the Woodsmith Shop as seen on PBS and I think you may be able to watch the video on their site. It has also been recommended by Wood magazine.
post #9 of 10 (permalink) Old 06-01-2011, 03:17 AM
First Name: Derek
Originally Posted by Phil P View Post
Derek
Regards
Phil
Perhas you haven't, but when I visited "Reprodux" furniture factory, that's the way they did it, and when fitting staircase spindles to strings and handrails it is done that way as well, even supplied ready cut in most cases.
Derek
post #10 of 10 (permalink) Old 06-01-2011, 10:57 AM
This was on the Woodsmith Shop episode that aired on 9-20-2010 at least on Direct TV. I still have it saved. It's on their site season 4 episode #401 Craftsman Coffee Table.
Free Woodworking Plans, Downloads and Videos - Woodsmith Shop
Whittier, CA.
Have a nice & safe day!
jlord is offline
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
Which Router To Get Etc? Gaia General Routing 10 02-24-2010 04:52 PM
