Solution for setting your variable speed router - Router Forums
post #1 of 6 (permalink) Old 05-30-2011, 08:33 PM Thread Starter
mpbc48's Avatar
Default Solution for setting your variable speed router
Hello all,
Since the diameter of the bit is used to determine the speed at which you should set your router and there isn't a really good way to know what your RPM's are, this little device could be the answer.
Amazon.com: Digital Photo Laser Tachometer Non Contact Tach: Home Improvement
I know it's not a necessity, but I'm rather partial to little devices like this.
You think I'm crazy? Wait till you meet my imaginary friends.
mpbc48 is offline
post #2 of 6 (permalink) Old 06-01-2011, 08:17 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Those are certainly cheap! Useful for a lathe, too.
Cheers
Peter
istracpsboss is offline
post #3 of 6 (permalink) Old 06-01-2011, 08:56 AM
Hi Mike
" little devices " = they do work, I have found out not one router is true with the sticker on them..but that could be my error I check them with the collet nut and not the bit that should be in them..and the collet nuts are not all the same OD.
but you need a flat spot to hold the tape that's needed to read the speed..
Originally Posted by mpbc48 View Post
Hello all,
post #4 of 6 (permalink) Old 06-01-2011, 09:15 AM
As you become familiar with your router the need for a device like this fades. Every router has it's own voice so to speak. The best tip for new users is to listen and see if the motor slows down or is laboring. This would show you are removing too much material in one pass for your router to handle. Another part of the voice is different sounds when routing like a skipping sound which is called chatter. This happens when the router is not cutting cleanly and could be caused by a dull bit or cutting against the wood grain. Listen when your router "speaks" to you.
post #5 of 6 (permalink) Old 06-01-2011, 10:18 AM
CharleyL's Avatar
First Name: Charley
With a photo tachometer you also need to be very careful that it doesn't see reflections off of shiny objects that are moving nearby, in addition to the part that you are trying to measure. The photo tachometer will add these stray reflections to the reflections that it sees from the tape and give you a totally different reading.
The best way to avoid this is to hold the unit so that it is not at a right angle to the tape. Holding so that it is at an angle of 30 - 45 deg to the taped surface will be much more accurate.
Charley
CharleyL is offline
post #6 of 6 (permalink) Old 06-01-2011, 10:53 AM
Hi
I found out the tach.must be pointed right at the tape strip, most of the collet nuts are black and the tach.will not pickup any reflections from the nut without the tape right in front of it..I tried the 45 deg.thing but the tach.didn't work at that angle..
it needs to see that break..
Charley
Modulated speed router problem. seanburns General Routing 6 08-19-2013 08:20 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Router Bit Sizes And Variable Speed Settings mack. Router Bits - Types and Usage 4 02-18-2010 11:33 PM
What Variable Speed Plunge Router should I buy? mack. General Routing 3 01-31-2010 03:09 PM
