need help with finger joints. - Router Forums
post #1 of 6 (permalink) Old 06-01-2011, 12:55 PM Thread Starter
First Name: Deadeye
Default need help with finger joints.
Hello, I am trying to wake a wagon wheel out of three peices of 2x material. My idea was to join the three peices using a finger joint router bit but have found this to be more difficult than I thought. Does anyone have suggestions in joining two 1-7/16" thick peices of wood end to end with finger joints? The set-up proceedure is what I really need. Thanks.
bfgpackerguy is offline
post #2 of 6 (permalink) Old 06-02-2011, 04:08 PM
Marco's Avatar
Welcome to the Router Forum bfgpackerguy.
I just have the basics down on finger/box joints but will throw my 2 cents at you. Trying to do that joint which will have some over lap plus an angle will be pretty tough to do plus time consuming. So unless you make a template and have your 3 piece circle allowing for the over lap, doing it with a router may not be the tool of choice.
Tracing out with paper first might be an option and then transfering that on to wood and cutting out with a hand/jig/band saw.
After a quick google this guy How to Make a Replica Wagon Wheel - wikiHow has a fairly easy plan to build a decent looking wagon wheel. The joints can either be biscuits or counter sunk screws.
Good luck
Galatians 5:13
Marco is online now
post #3 of 6 (permalink) Old 06-02-2011, 04:35 PM
Hi Deadeye
finger joints are Not easy, I would suggest using the T & G joints they are very strong and you can use your router table to put them in place easy..
Amazon.com: CMT 800.627.11 Tenon Cutting Router Bit Set: Home Improvement
CMT Orange Tools 800.627.11 Tenon Cutting Router Bit Set, 1/2" Shank
http://www.mlcswoodworking.com/shops...ingjnt0911.pdf
do it like the pictures below with a jig.
http://www.youtube.com/watch?v=JBM0RzElvRE
post #4 of 6 (permalink) Old 06-02-2011, 06:29 PM
Welcome to the router forum.
What is the diameter of the wheels you want to make?
Sydney, Australia
jw2170 is offline
post #5 of 6 (permalink) Old 06-03-2011, 10:36 AM
CharleyL's Avatar
First Name: Charley
Finger joints and box joints are not the same. Here is a finger joint router bit
Woodline USA - Finger Joint
It is intended for joining short pieces of wood to make longer "paint grade" stock. If you were cutting pieces of material to make a rim for a wheel you could probably use it to join the ends of the wheel rim segments together.
Is this what you are trying to do?
Charley
CharleyL is offline
post #6 of 6 (permalink) Old 06-03-2011, 10:51 AM
just some more
Program to make accurate through dovetails or finger joints ketzie Jigs and Fixtures 2 05-02-2011 08:47 AM
finger joints Sig Gebhardt New Member Introductions 5 10-06-2010 03:25 AM
Finger Joints J0B00 Jigs and Fixtures 18 08-24-2007 02:19 AM
finger joints ron dwyer Tools and Woodworking 3 11-28-2004 11:44 AM
