Correct depth for lettering - Router Forums
post #1 of 5 (permalink) Old 06-02-2011, 05:39 PM Thread Starter
First Name: Woody
Default Correct depth for lettering
Hi,
Whats the best depth for setting a cut bit for lettering?
Thanks!
wpage is offline
post #2 of 5 (permalink) Old 06-02-2011, 07:25 PM
dutchman 46's Avatar
First Name: Howard
That's a hard one to answer! I need to know the size and thickness of the wood, the size of the project. I would then more than likely run some letters, and look at the size, and if it will be properly sized to be seen. Smaller letters will use a smaller cut, and so on. That is what I find Myself doing, nd it works the best! Have fun!
John 3:16
dutchman 46 is offline
post #3 of 5 (permalink) Old 06-03-2011, 08:22 AM
Ralph Barker's Avatar
First Name: Ralph
I agree with Howard - adjust the bit depth based on the size of the lettering, and plan the thickness of the stock accordingly. This can vary based on the style of lettering, as well - i.e., whether the lettering is raised or inset, and whether it will be accentuated by paint or stain. One-inch lettering might require only 1/8" or so, 3"-4" might work with 1/4" depth, larger lettering might need 1/2" or more. In general, I like to keep the depth of cut to 1/3 the thickness of the stock, or less.
- Ralph
Ralph Barker is offline
post #4 of 5 (permalink) Old 06-03-2011, 08:39 AM
Hi Woody
I suggest 1/8" deep the max,if you look at a hand carved sign with chisels most are 1/8" deep the max,it's not how deep is how it is design...they will always stand out both ways..
Originally Posted by wpage View Post
Hi,
Thanks!
post #5 of 5 (permalink) Old 06-04-2011, 03:14 AM
derek willis's Avatar
First Name: Derek
Agreed, recommended depth is 3mm. which is equivalent to one eighth inch, if you try to go to more depth you will find router chatter develops so that the finish is not clean and smooth.
Derek
derek willis is offline
adjusting depth how to figure out the right depth CFLfan Portable Routing 3 02-06-2010 06:22 PM
setting depth for plunge router mag_rules General Routing 8 02-03-2010 12:58 PM
PC 4212 Bit Depth zach Jigs and Fixtures 9 11-17-2009 11:24 AM
Milwaukee depth adj not accurate to plunge base eganders General Routing 3 11-06-2009 08:09 AM
pc 890 series depth adjustment rabuckner General Routing 4 04-10-2005 01:20 PM
