Ryobi RE175 - Will not stay/lock in plunge position - Router Forums
post #1 of 4 (permalink) Old 06-04-2011, 07:36 AM Thread Starter
Default Ryobi RE175 - Will not stay/lock in plunge position
My Ryobi RE175 will not stay or lock in the plunge position.
no1texan is offline
post #2 of 4 (permalink) Old 06-13-2011, 07:53 AM
dutchman 46's Avatar
First Name: Howard
Hello N/a
I would guess that for some reason, the brass pad ,very small, slipped out of it's proper place! I have had that happened several times! I had the plunge handle loose. If memory serves Me, there is a small brass piece (1/4 by 3/42), or close to that. It can slide out of the hole and back inside the router! I needed to take it apart, and tap the unite on a piece of wood, covered with white cloth and it fell out. Then with a tweezers, put it back in place. It rubs on the shaft, I believe, and when You release the button, it grabs the shaft. I could not tell anything was wrong by touch. It felt OK. So it is worth a try!
John 3:16
dutchman 46 is offline
post #3 of 4 (permalink) Old 06-17-2011, 02:13 AM
Country: South Africa
First Name: Stan
I had the same problem with my Bosch POF 500A. Replaced the missing brass piece with a small ball bearing inside the locking handle slot. I was cautioned to tighten gently as it can damage the plunging rods if too tight. Fortunately I found the missing piece the next day on my garage floor.
Router Newbie is offline
post #4 of 4 (permalink) Old 06-17-2011, 12:22 PM
First Name: Howard
Thanks Stan! Something very important information! Might put it in the Ryobi folder. It's the only thing that ever went wrong with Mine!
John 3:16
Last edited by dutchman 46; 06-18-2011 at 11:46 AM. Reason: Finished My sentence :(
mounting Ryobi Plunge router in Wolfcraft table Denise16 Table-mounted Routing 5 01-30-2017 08:48 AM
building very simple router table for Ryobi Plunge fds Table-mounted Routing 14 06-20-2011 08:06 PM
What is the plunge depth of a Ryobi R163RTA? ageaton New Member Introductions 2 07-23-2010 01:42 AM
Mounting a Ryobi R175 Plunge Router bobtheengineer Table-mounted Routing 6 01-14-2009 01:34 AM
Ryobi plunge doesn't stay plunged! DHS Tools and Woodworking 3 02-22-2005 10:18 AM
