Hitachi M12V2 - Router Forums
post #1 of 6 (permalink) Old 06-05-2011, 06:46 PM Thread Starter
Default Hitachi M12V2
Hi all, newbie here but glad I found this forum.
I just opened the box on Hitachi M12V2 router. It should take 1/2 in bits but I can't get one to go in the collet. Any step I might be missing as I don't want to try to force one in.
Thanks in advance, MSUfan
MSUfan is offline
post #2 of 6 (permalink) Old 06-05-2011, 07:28 PM
papawd's Avatar
First Name: warren
Welcome......Does it have 2 collets , most routers do one 1/4" and one 1/2" look to see if Ya gotta change the collet.... If this is not the case check and make sure the lock is engaging allowing the unit to loosen and tighten all the way .... Good Luck
papawd is offline
post #3 of 6 (permalink) Old 06-05-2011, 09:50 PM
Gíday
Welcome to the router forum.
Thank you for joining us
Check that you do not have another collet in a plastic bag in the box.
The 1/4" collet may be on the router.
Sydney, Australia
jw2170 is offline
post #4 of 6 (permalink) Old 06-05-2011, 10:05 PM
Might be you got a 12 mm collet instead of 1/2". Take a caliper to it. 12 mm would caliper out to around .47", half inch would be .500"
John Schaben
jschaben is offline
post #5 of 6 (permalink) Old 06-06-2011, 02:42 AM
First Name: Ed
If it will accept 1/4" bits you need to remove the 1/4 " adapter from the collet loosen the collet and it should slide out.
edsaws is offline
post #6 of 6 (permalink) Old 06-06-2011, 10:43 AM Thread Starter
Thanks so much for all the replies. Finally figured out the problem, the collet was stuck in the shaft and wasn't coming out with the nut. Didn't know it was supposed to come out till I got to comparing the 1/4 collet and how it fits with the nut. Sometimes it takes me a while for the obvious to thump me on the forehead. Had this router 4 years or so, just now taking it out of the box.
Thanks again for all the help, looking forward to learning a lot here.
MSUfan is offline
Hitachi M12V2 plunge lock problem to avoid AlanWS General Routing 1 03-25-2011 07:57 PM
Router Hitachi M12V2 Manual Manuals Hitachi Manuals 0 12-16-2010 12:33 AM
Hitachi M12V2, Makita 3612 or Bosch 1617 Britax Table-mounted Routing 4 11-27-2009 11:57 AM
Router - Hitachi M12v2 or Triton 3 1/4 hp janthem Starting Off 6 08-10-2008 08:27 AM
hitachi m12v2 router fence cabin General Routing 2 11-30-2007 11:36 PM
