Brass setup bars - Router Forums
post #1 of 16 (permalink) Old 06-09-2011, 02:16 AM Thread Starter
Default Brass setup bars
I wasn't sure where to put this, so apologies if it's in the wrong place.
I've been looking for a set of brass setup bars from a uk supplier without much luck. Does anyone know where I can get a set in the uk?
mickleuk is offline
post #2 of 16 (permalink) Old 06-09-2011, 02:26 AM
Mike,
If you can't find 'set up bars' a bolt and screw merchant may have brass 'keys' in various sizes.
(square keys for locking pulleys/gears onto rods with keyway cut into rod?)??????
Sydney, Australia
jw2170 is offline
post #3 of 16 (permalink) Old 06-09-2011, 08:08 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
If all else fails, twist drill are very useful for this purpose and, as you know, come in a huge range of sizes.
Harry
harrysin is offline
post #4 of 16 (permalink) Old 06-09-2011, 09:19 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Try a model shop. Many stock K+S brass profiles in foot lengths that you could saw a 3" length off.
HTH
Peter
istracpsboss is offline
post #5 of 16 (permalink) Old 06-09-2011, 11:34 AM
Hex wrenches are also a handy substitute. With those you must be careful that you are measuring across the flats though.
John Schaben
jschaben is offline
post #6 of 16 (permalink) Old 06-09-2011, 11:57 AM
Country: Croatia
First Name: Peter
Bruce Engineering probably stock brass bar in various profiles.
Polly Model Engineering: Bruce Engineering - Materials & Consumables
Whereabouts in the UK are you?
Cheers
Peter
post #7 of 16 (permalink) Old 06-09-2011, 12:17 PM
Hi
You can also just use some wooden dowel stock if you don't like putting steel up to your router bits..1/8" to 1" is the norm..just make a nice little rack to put them in..
post #8 of 16 (permalink) Old 06-10-2011, 02:53 AM
harrysin's Avatar
First Name: Harry
Hi
You can also just use some wooded dowel stock if you don't like putting steel up to your router bits..1/8" to 1" is the norm..just make a nice little rack to put them in..
Bob, I hope that American dowels are more accurate than what's available downunder at Bunnings.
Harry
harrysin is offline
post #9 of 16 (permalink) Old 06-10-2011, 03:32 AM
derek willis's Avatar
First Name: Derek
Drills are the way to go, they never fail.
Derek
derek willis is offline
post #10 of 16 (permalink) Old 06-10-2011, 10:01 AM
Hi Harry
hahahahahahaha I think they are made in the Metric way, always a bit off...
That should be handy for him..
" Bunnings " is that like the Play Boy Club in the states ?
brass set up bars? awoodnut General Routing 21 02-02-2020 11:05 AM
Why do threaded guide bushings have right-handed threads sandyalexander Guide Bushings and Templates 30 02-23-2010 08:57 AM
Zeroing Out the Bit? Brass setup bars Evil Scotsman Router Bits - Types and Usage 2 07-31-2008 10:22 AM
Brass set up bars A-Pat-Co General Routing 5 04-18-2007 08:16 PM
Using brass setup bars Blind Bruce Table-mounted Routing 4 12-30-2006 03:09 PM
