Routing Vinly Fence Posts - Router Forums
post #1 of 4 (permalink) Old 06-10-2011, 10:17 PM Thread Starter
First Name: Phil
Default Routing Vinly Fence Posts
I am new to the forum and to Routing. I am building hyroponic planters using 5" x 5" 8' vinly fence post blanks. I am using a small rounter designed for routing couter tops and a 1/2" straigh router bit and have constructed a template (jig) for routing square holes for plant pots that will be inserted into the fence post which will be laying horizontal. I have no idea if this is the right tool for the job or the best way to do the job and would appreciate any insight others may have for such a task. I have attached pics of my project.
Phil
Name:	End Product - Planters.jpg
Name:	Close Up - Plnaters.jpg
plcowart is offline
post #2 of 4 (permalink) Old 06-10-2011, 10:25 PM
walowan's Avatar
First Name: Michael
That seems to be working fine for you so what's the issue?
walowan is offline
post #3 of 4 (permalink) Old 06-10-2011, 11:08 PM
Phil
Hi Phil - Welcome to the forum
Kinda hard to improve on success, looks good to me. Trim router was a good choice, light and easy to handle. Plunge would probably make life a little easier but they are rare in the laminate trimmer category. So far, looks like you're doin great
John Schaben
jschaben is offline
post #4 of 4 (permalink) Old 06-11-2011, 09:22 AM Thread Starter
First Name: Phil
Thanks for the feeback. I guess because I have never used a router before, and my jig was not exactly perfect, there might be some tips to do it better. I used 1/2 inch AC plywood which means I had to cut almost all edges. I do not have a table saw or a router bench. I used a skill saw with a straigh edge for a fence clamped to the plywood I was cutting. Consequently not all cuts were exactly the same hence the jig was not as square or precise as one would like. I was thinking that maybe if I used some other type of wood for the top part of the jig I might get better results.
plcowart is offline
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
Routing material between the fence and bit mpbc48 Table-mounted Routing 10 02-27-2011 03:16 PM
Reclaimed oak fence posts Neil Moon Show N' Tell 6 11-01-2010 03:28 AM
Routing material between bit and fence haef Router Bits - Types and Usage 5 10-15-2009 01:26 PM
