routing lettering on the edge of a plank - Router Forums
post #1 of 7 (permalink) Old 06-11-2011, 05:54 AM Thread Starter
Default routing lettering on the edge of a plank
Can anyone help me with routing lettering on the edge of a plank? I have some solid wood kitchen counter top that I am converting into chopping boards for family wedding presents etc. and would like to put a date or message on the edge surface, where it will not collect too much debris or be damaged by people cutting. I had thought of making or buying a router pantograph, but don't see quite how I can mount the board with its edge in the correct plane as most commercial ones are designed to rout the larger face surface. Any suggestions gratefully received. This will be a project for when I get back from my holidays.
safetyspot is offline
post #2 of 7 (permalink) Old 06-11-2011, 06:01 AM
derek willis's Avatar
First Name: Derek
John,
I think you would have to do it freehand and probably the way I have described in previous posts, write it in a script that you want, on your computer, print it to a size suitable, prime the timber with either shellac or water based varnish, stick on the template and rout over with a very fine round nose bit, or a vee bit, then finish in the normal way after removing the paper.
Derek
derek willis is offline
post #3 of 7 (permalink) Old 06-25-2011, 03:52 PM Thread Starter
Many thanks for the advice. I am just back from holiday so I will experiment once I have got myself sorted out.
post #4 of 7 (permalink) Old 06-26-2011, 05:07 AM
Country: New Zealand
First Name: Guy
I think also ... mark the board thickness lines on the edge of a thicker piece of wood [to be cut down to the thinner chopping board... then... after you have routed ... however its done you can skinny down the wood in a thicknesser to the right height... it might make it alot easier to route on... and reduce the threat and risk or tear offs.
Sounds brave to me though !
g
ixplorer is offline
post #5 of 7 (permalink) Old 06-26-2011, 09:14 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
In spite of having freehand routed signs, there are occasions when sending a project out to be laser engraved is the best thing to do.
Harry
harrysin is offline
post #6 of 7 (permalink) Old 06-26-2011, 09:27 AM
mpbc48's Avatar
I have some solid wood kitchen counter top that I am converting into chopping boards...
If you have not already cut it up, with some good planning, you can do the job while the countertop is still whole. Much easier than trying to route an edge.
You think I'm crazy? Wait till you meet my imaginary friends.
mpbc48 is offline
post #7 of 7 (permalink) Old 06-27-2011, 04:25 AM Thread Starter
Thanks for the advice. I think I will probably sandwich the board, which is about 40mm thick, between a couple of thicker pieces and use a Dremel in a router base or tile grout base to keep it steady for freehand routing.
Routing outside edge of a circle barryaclarke Table-mounted Routing 1 12-10-2010 08:34 AM
2X4 edge routing Thrake 2 General Routing 5 03-26-2010 02:21 AM
routing a previously routed edge Fishbaydoc Router Bits - Types and Usage 7 08-31-2009 11:40 PM
routing edge on round tom41 Jigs and Fixtures 34 01-06-2009 08:19 PM
Routing edge on plywood Dimitri Guest General Routing 2 10-20-2004 02:34 PM
