dovetails in plywood - Router Forums
post #1 of 9 (permalink) Old 06-11-2011, 01:33 PM Thread Starter
Default dovetails in plywood
Hello,
I am trying to make dovetails (Craftex Jig) with 3/4" maple veneered plywood. I am getting chipouts and tears. What am I doing wrong or do I use 3/4" solid wood to do this make dovetails?
Thanks, Bill
william1967 is offline
post #2 of 9 (permalink) Old 06-11-2011, 01:45 PM
Hi Bill
Baltic birch plywood works ok for dovetails but other than that use real wood..
Originally Posted by william1967 View Post
Hello,
Thanks, Bill
post #3 of 9 (permalink) Old 06-11-2011, 11:12 PM Thread Starter
Hi Bob,
Thanks for the tip. I have phoned around and I can pickup a couple sheets tommorrow.
I am just kinda starting out in my woodworking hobby.
post #4 of 9 (permalink) Old 06-11-2011, 11:29 PM
If you use a sacrificial backer board and it is good and tight to your workpiece you might get acceptable results but it depends partly on the plywood quality.
post #5 of 9 (permalink) Old 06-11-2011, 11:50 PM Thread Starter
That sounds good. So Charles would I set the sacrificial backer board in front of the work piece and clamp it in place and set the depth of cut a little longer? I can hardly wait to try this.
Thanks, Bill
post #6 of 9 (permalink) Old 06-13-2011, 10:46 AM
RJM60's Avatar
First Name: Robert
It's very difficult to get clean dovetails (or box joints) in plywood. Sacraficial boards tightly clamped both in front and behind are necessary.
The single biggest problem in communication is the illusion that it has taken place.
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #7 of 9 (permalink) Old 06-13-2011, 10:12 PM
I agree with RJM. Going in, the left side will want to tear out and going out, the right side will. Usually the back side is worse. If you cover both, there is a decent chance you will get an acceptable result.
post #8 of 9 (permalink) Old 06-14-2011, 12:07 PM
JKV
JKV's Avatar
If you use plywood, keep in mind that your joint can easly break, you would be much better off going with solid wood
JKV is offline
post #9 of 9 (permalink) Old 06-14-2011, 07:50 PM
First Name: Michael
They do make Special Router bits for that, And a Sacrafice Board underneath helps alot. also be carfull not to go too fast or slow use a junk board to check speeds.
sharpeguns is offline
routering dovetails in plywood ? peacefulwarrior Table-mounted Routing 6 01-17-2011 07:36 PM
Dovetails In Plywood rmaxa Router Bits - Types and Usage 8 11-30-2010 05:42 PM
Dovetails in plywood jadrats New Member Introductions 7 06-12-2010 08:03 AM
MDO for table top ebbonk Table-mounted Routing 1 01-04-2010 07:53 AM
Plywood dovetails blarsen General Routing 10 09-28-2009 11:35 AM
