Any tip for beginners? - Router Forums
post #1 of 14 (permalink) Old 06-11-2011, 02:36 PM Thread Starter
First Name: Kyu
Question Any tip for beginners?
I bought a Skil router (used reconditioned) and a Ryobi router ($99 special from HomeDepot) and used them to practice on a few pieces of wood. What would you recommend for a beginner project?
kdl4082inLA is offline
post #2 of 14 (permalink) Old 06-11-2011, 03:28 PM
First Name: Chris
A small shelf to mount in the living room rout a profile such as a round over on three sides. Making several light passes always routing the end grain first to prevent tare out. Try to find a cheap multibit set and experament with differant cutters and your pride and ideas will grow as you see the profiles. Soon you will be looking for higher grade bits.
Be carefull with your pride, better bits can get expensive. HaHa
roedercm is offline
post #3 of 14 (permalink) Old 06-11-2011, 03:35 PM
BigJimAK's Avatar
Kyu,
With two routers in your hand, the door's wide open for you! :-)
A couple of ideas would be to visit the forum specifically for people who are starting out in routing
Starting Off - Router Forums
as you will likely find some people have asked some of the questions you're thinking and some you haven't quite thought of yet.. <g>
Beyond that, freehand sign making is one good confidence-builder... here's a section on all kinds of sign making...
Sign Making - Router Forums
And some want to get into router tables to extend their routing capabilities. Here's a fun thread where many people have posted pictures of router tables they've made and bought. You might find it makes good inspirational dream fodder!!
http://www.routerforums.com/table-mo...ter-table.html
..and then of course there's anything else you can dream up. A router is (essentially) a portable cutting bit.. and do an amazing number of things. Some postings of what others have made are shown here
http://www.routerforums.com/show-n-tell/
Jim
BigJimAK is offline
post #4 of 14 (permalink) Old 06-11-2011, 04:57 PM
Honored Member
First Name: pat
Nothing.
I would buy some hardwood (FAS), like red oak, it's easy to rout.
I'd get a dozen cutters set to very shallow depths and rout the afternoon away.
Once confident you can hold the work and rout without burining stock, tearout, or splitting end grain, I'd take a shot at a simple router table and do it all over again.
That under control, I'd study woodworking. Material prep, layout, joinery, drilling, sanding, measuring, design and maybe finishing.
Now the router may play out. They do nothing without jigs, fixtures, well prepared material, and an operator with priors. Under your control, they solve many problems, many.
Quillman is offline
post #5 of 14 (permalink) Old 06-11-2011, 05:46 PM
Kyu, this is a perfect first project that will expand your routing ability:
http://www.routerforums.com/table-mo...tml#post127219
post #6 of 14 (permalink) Old 06-11-2011, 07:03 PM
Marco's Avatar
I'm with Chris......... a shelf will give you the expierience of routing an edge and some confidence...... Route edges on some 1x4 material and make a picture frame. A good starter bit kit is MLCS's 15 piece MLCS Router Bit Assortment Sets Gateway
Whatever project you pick put safety first and have fun!
Galatians 5:13
Marco is offline
post #7 of 14 (permalink) Old 06-11-2011, 08:35 PM
papawd's Avatar
First Name: warren
Welcome,and as stated practice
papawd is offline
post #8 of 14 (permalink) Old 06-12-2011, 03:25 AM
derek willis's Avatar
First Name: Derek
How about a nice break-front bookcase or display cabinet with raised panel doors and fluted columns, this should keep a beginner busy for a couple of years, alternatively, something for the kitchen like a spice rack, chopping board, saucepan shelf or paper roll holder, good luck you'll have fun.
Derek
derek willis is offline
post #9 of 14 (permalink) Old 06-13-2011, 05:06 AM
Country: South Africa
I think you should stick with something that you are interested in or you might needa round the house. This will ensure that you stay interested and not fall away in a couple of months. Maybe start out with some smaller items such as pictures frames or bird feeders and move on to some more substantial items such as furniture and cabinets.
LS1016L is offline
post #10 of 14 (permalink) Old 06-13-2011, 07:24 AM
First Name: del
Remember to feed the wood into the rotation of the bit. IF you do it on the other side the wood will shoot out so fast you will not see it go.
del schisler
port st. lucie, florida
del schisler is offline
Tip Rotator Mark Site Help and Suggestions 4 03-10-2008 10:22 AM
Tip from ShopNotes bobj3 Wood Scrolling 4 11-21-2006 10:47 AM
Bob's tip remembered reible Table-mounted Routing 3 08-20-2006 03:04 PM
email router tip BobandRick General Routing 12 11-23-2004 08:58 PM
