Best way to Chamfer panels sheets? - Router Forums
post #1 of 6 (permalink) Old 06-13-2011, 02:58 AM Thread Starter
Default Best way to Chamfer panels sheets?
I'm fairly new to woodworking and was wondering what is the best (fastest, easiest and most accurate) way to make 45 degree bevels on already cut to size panels. The panels would be 19mm (2/3 inches) MDF, with 0.4mm veneer on both sides (therefore accuracy is important).
I've got an 8ft cnc router, but it's only good for panels that haven't been cut to size as it never seems to accurately 'seek' the zero x&y axis of the sheet. Anyway, this is for commercial purposes so I wouldn't mind buying pro machinery to do this (apart from getting a better cnc router).
I used a handheld router years ago, but I remember that it had a bearing to 'ride' on a template. Obviously there would be nothing to ride on when making chamfers?
Thanks for any tips!
Baller is offline
post #2 of 6 (permalink) Old 06-13-2011, 03:59 AM Thread Starter
Sorry I meant 26mm (1 inch) panels. Would I be able to do this in 1 pass?
Baller is offline
post #3 of 6 (permalink) Old 06-14-2011, 12:15 AM
Chamfering an edge only requires a straightedge or guide fence attached to the router, or, if your piece is small, placed against the fence on a table.
post #4 of 6 (permalink) Old 06-14-2011, 11:41 AM
Hi - Welcome to the forum
Unless I'm missing something one of these should do the job:
MLCS Chamfer Router Bits
The bearing rides on the stock controlling the cut.
John Schaben
jschaben is offline
post #5 of 6 (permalink) Old 06-15-2011, 09:43 AM
CharleyL's Avatar
First Name: Charley
I would use a router table and fence with a chamfering bit. The table and fence should provide very good accuracy. A quick pass on all 4 edges should be quick, accurate, and easy.
Charley
CharleyL is offline
post #6 of 6 (permalink) Old 06-15-2011, 10:52 AM
RJM60's Avatar
First Name: Robert
If you're cutting a chamfer, then a chamfer trim bit (i.e. bearing on bottom) in a handheld (or table) would be the way to go; however, it sounds like want to cut a miter (not a chamfer). If you want to cut a miter, the easiest way would be to use a chamfering bit in a table. Once setup properly, you can quickly make accurate and repeatable cuts.
If you don't have a table, or if you prefer, you can use a handheld router and a guide (clamped to the panel); however, you will need to set it up for every cut. This isn't too difficult if you make "setback blocks". Clamp a guide to a piece os scrap and make the miter cut. Then measure the distance from the far edge (bottom) of the cut to the guide bar. Make two pieces of wood this long and then use them to set the guidebar on another piece of scrap. make another test cut and adjust the the setback blocks until they're perfect (or good enough). Keep these blocks and mark them for intended purpose, bit used and router used (even if you only have one - you might buy another ... ).
FYI:
A chamfer is an angled cut (usually 45°) between two perpedicular surfaces. A miter is an angled cut (usually 45°) between two parallel surfaces (like the sides of a box, or a picture frame) and is usually for creating a joint without showing end grain. Chamfers are for aesthetics, or safety (e.g. removing a sharp corner on a piece of metal).
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
Is there quick fix for slightly loose fitting raised panels? tpyke General Routing 4 06-16-2010 07:12 PM
Panels: Spaceballs being compressed on assembly? dawziecat Tools and Woodworking 4 02-26-2010 03:28 PM
finishing raised panels Padawan Learner Tools and Woodworking 9 11-11-2009 03:36 PM
Router for raised panels Jtomwoods Table-mounted Routing 5 11-03-2009 07:20 PM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 12:56 PM
