Can I get an adapter craftsman # 315 275000 - Router Forums
post #1 of 12 (permalink) Old 06-13-2011, 03:35 PM Thread Starter
First Name: kevin
Default Can I get an adapter craftsman # 315 275000
I bought an Craftsman router table with a 2HP Craftsman single speed 1/2 inch collet router. All of my router bits are 1/4 inch is an adapter available for this router and if so where?
Thanks Kevin1
kevin1 is offline
post #2 of 12 (permalink) Old 06-13-2011, 03:39 PM Thread Starter
First Name: kevin
The model on this router is craftsman # 315 275000
Kevin1
kevin1 is offline
post #3 of 12 (permalink) Old 06-13-2011, 04:36 PM
Thanks Kevin1
Here ya go
Router Bits, Woodworking Supplies, Woodworking Tools - EagleAmerica.com
Name:	collet adapters.jpg
John Schaben
jschaben is offline
post #4 of 12 (permalink) Old 06-13-2011, 04:47 PM
Adapter Bushings
MLCS Woodworking Adaptor Bushings and Ball Bearing Guides
post #5 of 12 (permalink) Old 06-13-2011, 04:51 PM
dutchman 46's Avatar
First Name: Howard
I would call the nearest parts ,Craftsman tools! I think that You will want the original Collete adapter. Most of them are made so they will not go in to the back of the opening.
John 3:16
dutchman 46 is offline
post #6 of 12 (permalink) Old 06-13-2011, 08:41 PM
Thanks Kevin1
Hi Kevin, OK, Craftsman lists two collect numbers here:
http://www.searspartsdirect.com/part...&prst=&shdMod=
They would be
Item #34
on diagram
Collett assy
PART NUMBER: 974252-003
and
Item #35
on diagram
Collet assy
PART NUMBER: 974252-005
Unfortunately they don't give a better description and I couldn't get in the Chat line to ask.
It does like you would need items 33, 36 and 37 in addition to 34 or 35 in order to complete the assembly.
Hope this helps
John Schaben
jschaben is offline
post #7 of 12 (permalink) Old 06-13-2011, 10:29 PM
welcome, Kevin
Sydney, Australia
jw2170 is offline
post #8 of 12 (permalink) Old 03-15-2013, 04:07 PM
Thanks Kevin1
Have the same unit with a 1/4" collet and im in need of the 1/2" willing to do a trade
jsains is offline
post #9 of 12 (permalink) Old 03-15-2013, 05:55 PM
Exclamation
Welcome to the forum N/a.
This chat was from 2011, so the issue has probably been resolved.
If you have the same model router (315.275000), can't you buy a 1/2" collet?
Sydney, Australia
jw2170 is offline
post #10 of 12 (permalink) Old 03-15-2013, 06:29 PM
First Name: Duane
One is available 13.99 from www.searspartsdirect.com, one is no longer available. Can't tell which is which. Might give them a call 1-800-252-1698.
Dmeadows is offline
Craftsman Quickrout 1/2" collet adapter lwbox CNC Routing 7 05-01-2011 09:56 PM
craftsman 315 245070 plunge router goofnoff General Routing 2 10-31-2010 03:19 PM
craftsman 315 router madre General Routing 2 08-28-2010 09:00 AM
Craftsman Pro Model 315 275000 clip44 New Member Introductions 4 03-15-2008 03:25 PM
Adapter for PC in Craftsman RT gtofan Table-mounted Routing 15 07-10-2006 10:05 PM
