finger joints - Router Forums
post #1 of 10 (permalink) Old 06-16-2011, 06:58 AM Thread Starter
trogpot's Avatar
First Name: nik
Default finger joints
Can you give me any help with setting up a finger joint on end to end wood,as opposed to a box joint
I am using it to use up offcuts from previous jobs
nik ellis
trogpot is offline
post #2 of 10 (permalink) Old 06-16-2011, 07:25 AM
First Name: del
nik ellis
go to this link and it will show you the bit for the job .
Finger-Joint Router Bit - Lee Valley Tools
del schisler
port st. lucie, florida
del schisler is offline
post #3 of 10 (permalink) Old 06-16-2011, 10:27 AM
RJM60's Avatar
First Name: Robert
http://www.routerforums.com/router-b...outer-bit.html
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #4 of 10 (permalink) Old 06-16-2011, 10:05 PM
Welcome, Nik
Sydney, Australia
jw2170 is offline
post #5 of 10 (permalink) Old 06-17-2011, 08:22 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Nik
You'll find this link more useful as they are in the UK:
Buy Axcaliber Finger Joint Router Cutter from Axminster, fast delivery for the UK
Cheers
Peter
istracpsboss is offline
post #6 of 10 (permalink) Old 06-17-2011, 11:23 AM
Phil P's Avatar
First Name: Phil
Didn't Trend used to do an end jointer? Correction, they still do. Although not for much longer it would seem
Regards
Phil
Phil P is offline
post #7 of 10 (permalink) Old 06-17-2011, 08:31 PM Thread Starter
trogpot's Avatar
First Name: nik
thanks for link.That is the cutter I bought.I have played about with it some more now and have nearly got the fingers to match up
nik
trogpot is offline
post #8 of 10 (permalink) Old 06-17-2011, 08:34 PM Thread Starter
trogpot's Avatar
First Name: nik
thanks for welcome,have played about with cutter some more and have a near perfect match now
nik
trogpot is offline
post #9 of 10 (permalink) Old 06-18-2011, 03:56 AM
derek willis's Avatar
First Name: Derek
Nik,
I bought a C.M.T. finger jointer about twelve years ago, I still use it regularly, as when joining you will tend to use only a certain number of prescribed thicknesses, take your time in setting up, get it right and then save a set up piece for the next time, I have a number and find it so very easy to get it right first time now. Good luck with it.
Derek
derek willis is offline
post #10 of 10 (permalink) Old 06-18-2011, 09:27 AM
Country: Croatia
First Name: Peter
UKP36 seems more realistic than the UKP160 they formerly charged for it.
Cheers
Peter
need help with finger joints. bfgpackerguy General Routing 5 06-03-2011 10:51 AM
Program to make accurate through dovetails or finger joints ketzie Jigs and Fixtures 2 05-02-2011 08:47 AM
finger joints Sig Gebhardt New Member Introductions 5 10-06-2010 03:25 AM
Finger Joints J0B00 Jigs and Fixtures 18 08-24-2007 02:19 AM
