Another router issue!!!! - Router Forums
post #1 of 6 (permalink) Old 06-16-2011, 09:39 PM Thread Starter
Default Another router issue!!!!
I'm new to all this so please bare with me. I have a new router and it was making sparks from within the motor housing. So far, I have discovered that this is normal. My other two concerns are: Is it common to break the inside of the collet, which holds the router bit? and Is it best to move the router slow or fast?
cb0811 is offline
post #2 of 6 (permalink) Old 06-16-2011, 09:50 PM
Welcome to the forum.
What make/model router are you using?
On some collets, the sleeve inside may be removed. Can you post a photo of your broken collet? (you can post a photo that is on your PC - not a link to a hosting site)
Slow or fast - depends on many factors (type of wood, bit size, depth of cut....)
too slow and the wood may burn, too fast and the router may be overworked..
just my 2 cents worth........
Sydney, Australia
jw2170 is offline
post #3 of 6 (permalink) Old 06-16-2011, 11:00 PM
papawd's Avatar
First Name: warren
I agree with James speed is determined by alot of factors. I have an idea in my head where mine routs best with some of the wood I use most of the time.. One thing I do is always make a practice run on some scrap piece or section Ya will be cutting off to determine speeds, I also make my practice run shallow as I do most of my routing usually 1/8"- to no more than 1/4" a pass ... Good Luck and happy sawdust makin
papawd is offline
post #4 of 6 (permalink) Old 06-17-2011, 12:47 AM
Hi - Welcome to the forum
Yeah, some sparking is normal in a new router until the brushes get seated, sparking accompanied by smoke is a bit more of a concern.
Not sure what you mean by "break the inside of the collet". Breaking anything is certainly not a good thing. Collets in most newer routers really consist of the collet itself and the collet nut. The collet itself is a cone shaped thingy with slots partially up the sides and a hole through the center for the shank of the bit. On most newer routers, the collet is a snap fit into the collet nut with the nut acting as a retainer. This snap fit allows the nut to extract the collet from the armature shaft preventing the collet itself from being jammed in there. If the collet/nut assembly has been tightened in the router with no bit installed, it is possible that the collet compressed itself enough to release from the nut. Pics of the situation would be great.
As far as feed rate goes, what James and Warren said
John Schaben
jschaben is offline
post #5 of 6 (permalink) Old 06-17-2011, 06:46 PM
JKV
JKV's Avatar
Good reply, that is the best way to learn. I agree with both of your replies, they do determin the type of wood you chose and always run a sample piece beforehand. If you got sparks coming from the router itself, you do have a problem. Who ever told you that is normal, needs to check themself. That is not right.
JKV is offline
post #6 of 6 (permalink) Old 06-17-2011, 07:23 PM
N'awlins77's Avatar
First Name: Lee
I agree with John and what cb0811 has "discovered" as sparks being normal. I may not be a router expert, but I've used MANY power tools in my 52 years, and if it's not normal for power tools to spark -- a little bit at least, and in it's beginning of use, then i've have owned/used nothing but abnormal power tools. I haven't noticed my new router sparking (but I use it in a well lit shop, or outside) but my 30 or so year old Craftsman router sparks a little till this day, when I first start it. Just sayin'....
N'awlins77 is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
I think my old router nearly killed me! peacefrog General Routing 23 01-26-2014 11:36 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
Cheap Sears Router Base Adjustment issue spambuster57 General Routing 3 11-19-2008 10:17 PM
