troubleshooting craftsman router - Router Forums
post #1 of 11 (permalink) Old 06-18-2011, 09:16 AM Thread Starter
First Name: Carole
Default troubleshooting craftsman router
I haven't used the router in about 18 months. now I can't even turn it on
carolel is offline
post #2 of 11 (permalink) Old 06-18-2011, 09:40 AM
xplorx4's Avatar
First Name: Jerry
Greetings Carol and welcome to the router forums, we are glad to have you join us.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 11 (permalink) Old 06-18-2011, 10:29 AM
First Name: Jack
1. Is the outlet its plugged into HOT? Sometimes a GFCI will trip and outlet is dead.
2. Can you rotate the shaft? Try spinning it around and see if it moves free. It could be it is just gummed up and needs to rotate some to free it up.
It also could be a bad switch.
barking spider is offline
post #4 of 11 (permalink) Old 06-18-2011, 03:54 PM
dutchman 46's Avatar
First Name: Howard
If it was, or is dusty, the brushes could be a problem! Try blowing it out in front with a vacumn, then plug it in. Try a little extra blowing at the brushes. Wear goggles! If there is no life, start at the plug-in and check for power. start with the easy things, and work to the more labor intensive repairs! Brushes could be a problem.
John 3:16
dutchman 46 is offline
post #5 of 11 (permalink) Old 06-18-2011, 05:59 PM
BrianS's Avatar
First Name: Brian
Is it an older model Craftsman router? Check the shaft lock. If it's still engaged, as it would be when removing/replacing a bit, it will not start. (Don't ask how I know!!)
Brian
(Origin uncertain)
BrianS is offline
post #6 of 11 (permalink) Old 06-18-2011, 07:00 PM
First Name: Howard
Some of the routers had a handle at the top of the router. It is locked, the lever will stick out a bit, and it will say shaft locked Push that to wards the center of the router. It will slide at a 90#angle to the router shaft. I hope this helps
John 3:16
post #7 of 11 (permalink) Old 06-20-2011, 10:22 PM
First Name: Jack
Oh, HEAD SLAP! I forgot about the shaft lock. Yep, could be that too.
post #8 of 11 (permalink) Old 11-19-2019, 10:00 AM
it is a 1.75hp plunge router several years old but only used once then sat on shelf. The motor is not frozen up and the lights come on but all I get is a humming sound from the motor.
splinter1 is offline
post #9 of 11 (permalink) Old 11-19-2019, 10:14 AM
the motor turns by hand but only hums when switched on,the lights do work when switched on.
post #10 of 11 (permalink) Old 11-19-2019, 10:17 AM
Brushes....
Base Plate for Craftsman Router Steve1946 Craftsman 12 12-04-2014 06:22 PM
Craftsman Router with Wolfcraft® Folding Router Table WoodCrazy Table-mounted Routing 2 01-05-2010 01:12 AM
Craftsman Router Not Working Properly cosmokramer General Routing 13 10-15-2009 06:28 AM
