tear outs on end of cuts????? - Router Forums
post #1 of 8 (permalink) Old 06-20-2011, 07:02 PM Thread Starter
First Name: Steven
Default tear outs on end of cuts?????
i'm fairly new to the world of routers. i've been doing general woodwork for about ten years but recently i have began to venture into finish/fine woodworking. The problem i have having is when using a freud rail and stile bit set to cut cabinet door i am experiencing a significant amount of tear out at the end of the cut esp when cutting the rails. i'm am using a pc693 router and a set of used bits i purchased from a buddy. the wood of choice has been poplar as i am just learning the ins and out of router ops. is the router turning to fast for the bit as it is not variable speed?
smboudreaux is offline
post #2 of 8 (permalink) Old 06-20-2011, 07:20 PM
Hi Steven
" set of used bits " Dull bits will do it every time, a push block (back up block) will help.
Don't forget you are trying to cut the ends of straws on all end cuts and the bits need to be very sharp.
Just a note,,you don't need to buy both bits at one time when the rail bits gets dull, almost all of Freud bits are made as a match sets, the style bit will out last the rail bit 3 to 1 the norm.
http://www.amazon.com/s/ref=nb_sb_no...+bit&x=19&y=21
post #3 of 8 (permalink) Old 06-21-2011, 12:03 AM
papawd's Avatar
First Name: warren
Welcome, I agree dull bits will catch Ya every time. I most of the time make small depth cuts and will also make a back cut very lightly to clean everything out...
papawd is offline
post #4 of 8 (permalink) Old 06-21-2011, 07:23 AM
CharleyL's Avatar
First Name: Charley
Clamping or holding a piece of scrap to the end of your stock so that your cut extends from the stock into the scrap, is the best way to avoid tear out. A sacrificial push block works well for this if working on a router table. If you are holding your router, then add a scrap to the end of your stock so that your router bit will cut into it as it completes the rabbet or other cut that you are making.
Charley
CharleyL is offline
post #5 of 8 (permalink) Old 06-21-2011, 07:39 AM Thread Starter
First Name: Steven
thanks for the insight fellas. i'll try the push block. i intend to replace these bits soon so if dull bits are the culprit the problem will be remedied then.
post #6 of 8 (permalink) Old 06-21-2011, 08:35 AM
papawd's Avatar
First Name: warren
PMC Machinery in Hammond has the best selection of bits that I know around here. There is a tool outlet that has opened in the Taenger outlet mall (Cabella's exit) they have mostly reconditioned tools and a small selection of bits, last time I was there picked up a set to be used for spares...
papawd is offline
post #7 of 8 (permalink) Old 06-21-2011, 10:04 AM
JKV
JKV's Avatar
You will need to still put a piece of stock behind your railes when cutting, even with brand new cutters you will have that blowout if you dont.
JKV is offline
post #8 of 8 (permalink) Old 06-21-2011, 01:11 PM
Hi
The easy way is to use wider stock, mill the ends cuts 1st. then rip the stock to size and you can just cut of the rip outs if you have any
Ski question os smoothing end grain, bit, speed, etc TanOak Portable Routing 4 11-07-2010 09:03 AM
end on end dovetails brook trout New Member Introductions 2 10-03-2010 01:11 AM
End Mills vs.Rrouter Bits For Mortising. Gaia Router Bits - Types and Usage 8 07-03-2010 12:37 PM
Raised Panel End Grain Question. AlanSweet The Finishing Touch 6 05-17-2010 08:32 PM
Tear out when routing end grain cuttin board RealCom Table-mounted Routing 8 07-10-2009 09:33 AM
