Router bits and depth - Router Forums
post #1 of 3 (permalink) Old 06-21-2011, 03:25 AM Thread Starter
Default Router bits and depth
Hi all,
I am new to the forum and to routing. I live in South Australia and I am reasonably handy and generally do the fix it jobs around the house.
My question is: I have a portable Plunge Router that takes 6.4mm shaft bits and I'm building some shelves using 16mm melamine. It appears that the bits are not deep enough to edge the sheets. Does this mean that I need to buy a bigger router to that takes the larger shaft bits?
Thanks for the anticipated help and advice.
Bugalug is offline
post #2 of 3 (permalink) Old 06-21-2011, 03:32 AM
derek willis's Avatar
First Name: Derek
What you have there is a router with a 1/4 " collet therefor you will use 1/4 " shank cutters, go online or look in any catalogue,( I don't know whose you use over there), and you wil find cutters of the right shank size but with enough depth of carbide to do your trimming.
Derek
derek willis is offline
post #3 of 3 (permalink) Old 06-21-2011, 06:04 AM
Originally Posted by Bugalug View Post
Hi all,
Welcome to the forum.
Try CARB-I-TOOL
they will have the cutter you want.
What make/model router do you have?
Sydney, Australia
jw2170 is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
