uk mitre lock cutters - Router Forums
post #1 of 10 (permalink) Old 06-24-2011, 01:37 PM Thread Starter
ggroofer's Avatar
First Name: philip
Default uk mitre lock cutters
Hi folks, i'm going to invest in a mitre lock cutter the only problem is my budget isn't to big so that gives me the choice between the 'rutlands' brand or the 'axminster' brand .Can anyone suggest which brand to go for? ...or is there another mid priced brand available in the uk? thanks Philip.
ggroofer is offline
post #2 of 10 (permalink) Old 06-24-2011, 05:57 PM
mpbc48's Avatar
Hi Philip,
1 pc 1/2" Shank 1-3/4" Dia. 45° Lock Miter Router Bit | eBay
George ships worldwide. I'm not sure what it would be to the UK, but it is worth checking out.
There are a number of members here that like and use his router bits.
You think I'm crazy? Wait till you meet my imaginary friends.
mpbc48 is offline
post #3 of 10 (permalink) Old 06-24-2011, 06:18 PM Thread Starter
ggroofer's Avatar
First Name: philip
Default mitre lock router bits
Originally Posted by mpbc48 View Post
Hi Philip,
Thanks mike,i'm def' gona check these bits out!....bits of this type are very expensive in the uk...Philip.
ggroofer is offline
post #4 of 10 (permalink) Old 06-25-2011, 04:51 AM
derek willis's Avatar
First Name: Derek
Philip, just had a look at them on ebay, got to be well worth the trying if that's all they cost, try and use 1/2" shank if you can as a lot of strain goes onto this sort of bit, mine is a C.M.T. bit and excellent value it is.
Derek
derek willis is offline
post #5 of 10 (permalink) Old 06-25-2011, 05:44 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
George's stuff is OK. I've lots of his bits. I just wish he was over here ! I get mine via kind friends travelling over here hand carrying stuff for me. Otherwise the weight tends to make the postage high and we get VAT and import duty levelled on not just the price of the tool, but the postage as well !
Before buying, note that there are two or three different sizes, depending on how thick the wood is that you are joining.
Cheers
Peter
istracpsboss is offline
post #6 of 10 (permalink) Old 06-25-2011, 06:08 AM
First Name: Derek
That sort of makes a bit of a mockery of it after all, so I guess it's stick to uk bits after all.
Derek
post #7 of 10 (permalink) Old 06-25-2011, 04:07 PM Thread Starter
ggroofer's Avatar
First Name: philip
Default mitre joint cutters
Hi Derek,those C.M.T bits do look nice but my budget doesn't quite stretch that far at the minute ! Have you ever used the axminster 'tornado' bits or the rutlands 'axcaliber' bits? those would be more in my price range. Usually I would use the trend 'craft pro' range but there is A limited choice. Thanks Philip.
ggroofer is offline
post #8 of 10 (permalink) Old 06-26-2011, 03:37 AM
First Name: Derek
Philip,
I have a number of Rutlands Excaliber bits and find they are quite adequate and if this is in your price range then I should go for it, remember that Lock Mitre bits cannot be re-ground.
Derek
post #9 of 10 (permalink) Old 06-26-2011, 07:20 PM
As long as what you buy from the US is under the Customs & VAT threshold of 18 , (15 from1 Nov 2011) its worth buying from the US provided the postage is reasonable. I have never had a problem buying stuff on ebay from the US.
charlesb is offline
post #10 of 10 (permalink) Old 06-27-2011, 01:13 AM
Mike Wingate's Avatar
First Name: mike
Try the ones from MLCS, I have 2 of them and a CMT, all 3 sizes, vey useful, but make sure all your wood is of the same thickness!
Mike Wingate is offline
Baby Lock mitre bit wanted in the UK andersonec Table-mounted Routing 3 10-23-2010 01:17 PM
mitre lock bits gnarlywood General Routing 4 08-06-2010 07:15 PM
intro and mitre lock bits gnarlywood New Member Introductions 5 08-06-2010 04:13 PM
Question about lock mitre set up distrbd Table-mounted Routing 4 05-09-2010 04:28 PM
Lock Mitre Router Cutter Ianelm1930 Router Bits - Types and Usage 9 10-24-2009 03:18 PM
