Faulty locking Handle - Router Forums
post #1 of 5 (permalink) Old 06-28-2011, 12:02 PM Thread Starter
First Name: Ian
Default Faulty locking Handle
Hi Forum
I have got problem when I plunge my router it does not lock !!!. I have an old Dewalt router DW613 L type C . Normaly it lock by twisting the handle, does anyone know how to take the handle off so I fix the problem .
I would really appreciate any help
best regards
hibbie
hibbie is offline
post #2 of 5 (permalink) Old 06-28-2011, 12:39 PM
Phil P's Avatar
First Name: Phil
Hello and welcome to the forum
The locking handle simply unscrews all the way out and it should have a brass insert piece at the end which bears against the column
Regards
Phil
Phil P is offline
post #3 of 5 (permalink) Old 06-28-2011, 02:00 PM Thread Starter
First Name: Ian
Hi phil I have tried that but it just keeps turning and nothing happening. any other ideas
many thanks
hibbie
hibbie is offline
post #4 of 5 (permalink) Old 06-28-2011, 02:47 PM Thread Starter
First Name: Ian
Hi forum it look like the threaded screw is turning in the handle any suggestions.
I do have a spare handle
many thanks
hibbie
hibbie is offline
post #5 of 5 (permalink) Old 06-29-2011, 09:54 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Do you mean that the handle no longer grips its stud? Will it pull off altogether so that you could reattach it to the stud so that you could then get the stud to turn?
Cheers
Peter
istracpsboss is offline
Triton crank handle position? joel74 Table-mounted Routing 6 04-15-2011 10:01 AM
Missing locking key on router Rowantree General Routing 2 07-11-2009 04:14 AM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
Push Stick Handle garryjc Jigs and Fixtures 4 10-04-2007 08:38 AM
