Goat or Gloat - Router Forums
post #1 of 11 (permalink) Old 06-29-2011, 11:36 AM Thread Starter
SteveMI's Avatar
First Name: Steve
Default Goat or Gloat
Hi,
I bought a router CHEAP at a yard / estate sale. The goal was to use it in a dedicated fixture. Problem is that I cannot get the base to adjust on the motor.
It is a Bosch 1604 with 0 60 19054 39 motor and 3 605 702 600 base.
It had obviously been sitting for a while. A bit was frozen in the chuck, but some WD-40 squirts over two days fixed that.
Completely loosened (bolt out) the clamp, but it will not turn. Encouragement from a rubber mallet didn't help either.
Anyone still have or know about these?
Steve.
SteveMI is offline
post #2 of 11 (permalink) Old 06-29-2011, 04:25 PM
The motor is a straight "barrel" and the base is most likely corroded enough that they are seized together.
If you've got the locking bolt out completely then the only thing I could suggest is the let some lubricant work it's way down between the motor and base and see if that will loosen it up.
TomE is offline
post #3 of 11 (permalink) Old 06-29-2011, 05:07 PM
Marco's Avatar
try spraying some penetrating oil like Liquid wrench followed by a heavy dose of encouragement therapy
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #4 of 11 (permalink) Old 06-29-2011, 05:49 PM
Absolute last desperate measure if all else has failed is to try some Coca Cola. The phosphoric acid in it might eat through the corrosion. Many years ago we used to use it to loosen split truck rims.
post #5 of 11 (permalink) Old 06-29-2011, 09:28 PM Thread Starter
SteveMI's Avatar
First Name: Steve
Tom - really appreciate the pictures. It is as simple as it seems, but I was worried that I was missing something really obvious and simple.
I'm not sure if the WD-40 will work that good since the surfaces are plastic and aluminum. That will be first and cola idea sounds like it would work as the second attempt.
Steve.
SteveMI is offline
post #6 of 11 (permalink) Old 06-29-2011, 10:20 PM
Steve.
Hi Steve, I would be concerned about the sugar as stuff in the coke gumming it up some more. About the best penetration oil I've found is PB Blaster, available at any parts store. Also, automotive brake cleaner will blow out and clean up a lot of junk. A plus here is that is leaves no residue.
Good Luck
John Schaben
jschaben is offline
post #7 of 11 (permalink) Old 06-30-2011, 09:20 AM
bobbotron's Avatar
First Name: Rob
Add some time between the liquid wrench and encouragement therapy. That stuff needs time (at least a half hour?) to work.
I work at a community bike shop, we see a lot of siezed parts, some of them soak in oil for a long time before they come free. The worst is two different metals clamped together, galvanic corrosion is a pain.
bobbotron is offline
post #8 of 11 (permalink) Old 06-30-2011, 09:25 AM
Hi
A good heat gun works well, a LITTLE heat will free almost anything..
Rap the motor with a wet rag and heat the outside motor frame (case) and it will come free with a little tap the norm..
post #9 of 11 (permalink) Old 07-01-2011, 12:18 AM
The Warthog's Avatar
First Name: Roger
Good Luck
You could always try diet coke...
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #10 of 11 (permalink) Old 08-04-2011, 11:17 AM Thread Starter
SteveMI's Avatar
First Name: Steve
Default Success!!
I finally got to the WD40 advise and it worked. First I applied it from one side, waited couple hours and applied from the other side, then let sit overnight. Just slight bit of persuation with a rubber mallet and it seperated.
It is still tight after sanding the inside of the base with 220 and using a green pad on the router housing. I am goning to let it dry a day or so before doing anything else.
So, now for the gloat. The Makita, two (2) Bosch Colts and a Craftsman Router Lathe for $90. The router lathe only looks to be missing the crank handle.
Steve.
SteveMI is offline
Bosch 1619 EVS Router Gloat GoonMan Table-mounted Routing 3 07-08-2013 08:59 PM
Wood Gloat BernieW Woodturning and Lathes 5 05-14-2009 10:20 AM
I got a wood gloat Glenmore Woodturning and Lathes 7 08-25-2008 03:06 AM
Tool Gloat of the day! tim lemley Tools and Woodworking 11 01-28-2008 09:50 PM
Christmas Gloat :) challagan Portable Routing 3 01-09-2007 07:47 AM
