Can't lock bit in collet - Router Forums
post #1 of 7 (permalink) Old 07-01-2011, 02:26 PM Thread Starter
First Name: Rob
Default Can't lock bit in collet
A while back I bought a cheap trim router from Harbor Freight. (I know, going cheap was my first mistake.)
I insert the bit, tighten the collet as much as I can and I can pull the bit out without the slightest bit of effort.
Any ideas on how to remedy this?
RobFV is offline
post #2 of 7 (permalink) Old 07-01-2011, 03:05 PM
First Name: Gareth
Have you check the collet size some are 1/2 inch others are 12mm, the collet needs to match the cutter
GarethHarvey is offline
post #3 of 7 (permalink) Old 07-01-2011, 03:07 PM
dutchman 46's Avatar
First Name: Howard
You may have a 8 mm. opening! Are You sure that there wasn't another Colet in the tool baag's?
John 3:16
dutchman 46 is offline
post #4 of 7 (permalink) Old 07-01-2011, 03:14 PM Thread Starter
First Name: Rob
The router and the collet are both 1/4"
RobFV is offline
post #5 of 7 (permalink) Old 07-01-2011, 03:22 PM
Guest
First Name: Regis
Rob,
Do not "bottom" the bit. Insert the bit to a depth just short of the bottom of the collet and see if that solves the problem.
Regis
48394 is offline
post #6 of 7 (permalink) Old 07-01-2011, 03:29 PM
kp91's Avatar
First Name: Doug
take it back, bring your bit with you, find another one that will bite on the bit before you leave the store. The one great thing about HF is they pretty much take anything back.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #7 of 7 (permalink) Old 07-04-2011, 07:56 AM
I've had the same problem with Chinese routers. You might try removing the collet and checking the inside of the shaft. I've found them to have coarse milling marks not allowing the collet to tighten. Also check the collet itself for the same problem and for any debris in the slots. After polishing them both they seem to work ok. Hope this helps.
Joham is offline
Craftsman 17400 collet won't grip bit BillHi Router Bits - Types and Usage 1 10-22-2010 04:43 AM
my new lock bit grimreeper Router Bits - Types and Usage 7 05-20-2010 11:52 PM
Correct way to install a router bit Goldglv Router Bits - Types and Usage 22 04-07-2010 09:46 AM
Skil lock miter bit Schechner Router Bits - Types and Usage 11 10-19-2009 05:25 PM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 10:51 AM
