Stotts Dovetail Template - Router Forums
post #1 of 8 (permalink) Old 07-03-2011, 01:38 PM Thread Starter
First Name: Kelly
Default Stotts Dovetail Template
Has anyone tried a Stots Dovetail Template Master? It looks quite interesting.
KR
Kelly Rittgers is offline
post #2 of 8 (permalink) Old 07-04-2011, 02:04 AM
First Name: Randal
I was/am interested, but a couple of things:
One, I was hoping to share it with my father, but the license agreement seems to eliminate that (neither one of us would use it enough to justify one by ourselves).
Two, I have searched here, and read reviews, and it seems to get shot down somewhat, as a (paraphrased) kit to make a dovetail jig, and it requires certain bits.
LinuxRandal is offline
post #3 of 8 (permalink) Old 07-04-2011, 09:42 AM Thread Starter
First Name: Kelly
I watched a bunch of videos on it. Doesn't seem bad for 85.00 which is what I think it sells for with bits. I am sure the videos make it look easier than it really is. I think it comes with a money back guarantee. Could be wrong.
KR
post #4 of 8 (permalink) Old 07-04-2011, 10:50 AM
Twill57's Avatar
I think it is worth the small investment. Once the template is made, set-up is very easy and accurate. Works well from drawers to blanket chests.
Twill57 is offline
post #5 of 8 (permalink) Old 07-04-2011, 11:50 AM
Honored Member
First Name: pat
Thinkin' the system requires 3/4" MDF as the templet material. (Thinner stock is too flexible). A strange one for me, unless there have been changes since I last studied.
Appreciate, that way & dovetail bits are already working beyond their safe engineering limits (extreme narrow neck, skinny shanks and long flute fragility) so to make them work with a 3/4" thick templet, (demanding more cutter extension), just doesn't make sense to this novice.
Quillman is offline
post #6 of 8 (permalink) Old 07-04-2011, 01:01 PM
First Name: Randal
That is something else I wondered about. If one uses something other then MDF (some plastics), couldn't one make one thinner?
Even if 3/4" I would be tempted to use plastic that might last longer then MDF.
post #7 of 8 (permalink) Old 07-04-2011, 01:16 PM
Hi
I have the Stotts jig, it's not to bad, you don't need to made a new dovetail jig to use it, it's just a way to keep the master jig like new or if you want to make a longer jig.
The MDF stocks works well for making a new jig but you must get the bits with the Stotts jig, it's base on the 1/2" bearing ,it's must have item..I many dovetail bits with the 1/2" bearing on them and they will just not work with the jig..
post #8 of 8 (permalink) Old 07-04-2011, 02:56 PM
Honored Member
First Name: pat
"If one uses something other then MDF (some plastics), couldn't one make one thinner?"
Laminated phenolic (usually canvass) is the gold standard for a thin dovetail templet; it is stiff enough but requires some heavy duty routing & milling to create. Anybody can make a dust-bowl MDF templet.
Thermoplastics (acrylic, polyethylene, P.carbonate) are not stiff enough when thin.
Open tines (the comb) are just so poorly supported, thicker stock is called for.
Notwithstanding, and Keller has exploited this, a thin strong templet in plastic is possible if the tines are continuous. That is, the legs possess the required straight or dovetailed angle & length but they keep going way beyond their required length. They are unbroken like a lasso.
Quillman is offline
Dovetail template Anthony Mootra Guide Bushings and Templates 10 04-09-2010 09:21 PM
For Sale: Sears/Craftsman 2579 router dovetail joint template kit. $25, Craigslist Anchorage BigJimAK Woodworking Classifieds 0 01-09-2010 06:40 PM
Make a 1/4" dovetail template Solt Guide Bushings and Templates 5 12-08-2009 01:18 PM
Rockler dovetail jig template Mike The Bargain Bin 1 07-14-2007 09:07 PM
