newbie brush question - Router Forums
post #1 of 4 (permalink) Old 07-07-2011, 01:44 PM Thread Starter
First Name: Rob
Default newbie brush question
I see numerous references to brushes in routers (and other tools). Pardon my ignorance, but...what exactly are brushes? On the same topic, how long do they typically last, is replacement difficult, etc.
Any guidance is appreciated.
RobFV is offline
post #2 of 4 (permalink) Old 07-07-2011, 02:00 PM
Hi Rob - Welcome to the Forum
Brushes are not something you would normally be concerned about, until there is a problem with the tool running, or not running. They are simply a block of carbon molded to a, usually copper, wire and conduct electricity to the motor armature. Because carbon is relatively soft they are subject to wear and need to be periodically changed. By periodically, it is normally many, many hours of usage before there will be a problem. Problem will usually manifest itself in a failure to run.
As far as ease of changing, some of the older motors need to be dismantled but most modern tools have access caps near the end of the motor so changing brushes is very easy. The caps will be on the side of the motor away from the load end. In example, on a router they will be on the opposite end of the motor from where the bit is installed and on a saw, on the opposite end from the blade
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 07-07-2011, 02:31 PM Thread Starter
First Name: Rob
thanks!
RobFV is offline
post #4 of 4 (permalink) Old 07-07-2011, 04:51 PM
TWheels's Avatar
Rob,
Just to elaborate on John's response, if you look at the owner's manual there should be a picture showing where the cover for the brushes and what the brushes look like. For example, the retired moderator Hamilin posted the owner's manual and parts breakdown for the router with which I have the most familiarity, the Makita 3612C. Page 13 of the owner's maunal shows a clear picture and describes how to change them and the Parts Breakdown page 1 shows exactly where the brushes and brush covers are located. These manuals can be found as downloadable .pdf files in Router Reference subforum. There are many other brands and models of routers described there also.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is online now
Newbie table/fence question ds53652 Table-mounted Routing 7 04-06-2015 08:36 AM
Newbie to forum with T&G question jrushmeyer New Member Introductions 5 02-10-2009 03:25 PM
newbie question falcn63 Table-mounted Routing 1 01-24-2006 09:23 PM
Newbie question on router mounting WallyB Table-mounted Routing 5 06-06-2005 08:20 AM
