tenons on the router - Router Forums
post #1 of 4 (permalink) Old 07-09-2011, 10:30 AM Thread Starter
First Name: Bonnie
Default tenons on the router
Hi, I'm new to this forum, and I've used routers before in making edge profiles and dados, but I'd like to learn more about tenoning, grooving etc...
Today I set up a slot cutter and made a nice 1/4 " groove on a board edge (3/4" pine), but for some reason the bit seems to be leaving a tiny "ledge" on one side of the groove. So I adjusted everything for a depth of 3/8"-but one side of the groove is maybe a 64th deeper. What am I doing wrong? This is a Craftsman router mounted in a table, everything is solid and working well, but the groove is off.
Bonnie is offline
post #2 of 4 (permalink) Old 07-10-2011, 03:24 AM
derek willis's Avatar
First Name: Derek
Bonnie there has been quite a bit about teoning with a router, a very easy method you will find in my dowloads page five and thereabouts. As for your slot cutting, is your setting moving whilst actually doing the groove cutting, to avoid this you must apply the plunge lock. Good luck.
Derek
derek willis is offline
post #3 of 4 (permalink) Old 07-10-2011, 09:06 AM
Hi
Buy a new slot cutter router bit, they are not all made the same..the lower price ones will do that..
post #4 of 4 (permalink) Old 07-11-2011, 07:16 PM Thread Starter
First Name: Bonnie
Thanks for the info. The bit I'm using, is very loud and obnoxious on the router table. I still tend to think it's something in the set up that I'm doing, maybe the bottom of the groove is ledged because the table is unlevel? At this point, I'm grasping at straws. I tried to make the cut with the grooving part of a cope and stick bit, but the same thing happened. For now it's back to the table saw. Thanks again!
Bonnie is offline
Making tenons without a router table Bogydave Jigs and Fixtures 8 06-13-2011 08:09 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
