Router plate - Router Forums
post #1 of 4 (permalink) Old 07-10-2011, 02:58 PM Thread Starter
First Name: Alfredo
Default Router plate
Hi there you guys. I am new to the forum, I already introduce myself in the introduction forum, but now I am into my routing 101 questions. OK, i have a Crafstman model 171 router that I bought maybe three years ago along with one of the small plastic router table. However, it is now when I am going to use it for the first time. Between then and now I discarded the table and kept the router and I do not know if the router brought its plate or not , or if i discarded it along with the table; so final result I have a brand new old router without plate much less a sub base plate.
Number one: Do I need to find or make a plate or I can make a sub base plate and put it directly on the router without the primary base?
Also, I cannot post pictures yet because this is my second thread, but my router's base has a buch of holes underneath of different sizes and in different positions,
Number two: What are there for and wich ones do I need to use to attach a sub base plate?
Finally I have read some of the old threads about the sub base plate subject and I have desided to go with an Idea that Noob posted which is a square sub base plate with diferent distances between the router tip and each side of the sub base plate.
Number three: is that a good idea for a newbie? and how can I attached it if I do not know what holes to use of those underneath my router base.
I hope I am not to much of a burden by asking too many questiosn at onece.
Thank you so much
Alfredo
Amalgam is offline
post #2 of 4 (permalink) Old 07-10-2011, 04:25 PM
Marco's Avatar
I was in a similar situation needing a base plate for a Craftsman and if I had to do it all over again I would get the Milescraft baseplate that comes with metal bushings Amazon.com: Milescraft 1211 Base Plate Metal-Nose Bushing Set for Routers: Home Improvement . It will fit your router plus you have some guide bushings to get you going. Milescraft may have something you might get interested in down the road like sign making or doing inlays Amazon.com: Milescraft
As for Router Plates for a router table.................. all deprnds on if you are buying a table or making your own. MLCS has a decent plate for 34.95 Router accessories all the way up to$$$$ they also carry Router Tables and a good price on Router bit sets MLCS 15 Piece Router Bit Sets
Harbor Frieght used to have a great price on Router table Insert Plates but do not carry them any longer... seems that one of our members bought them all up!
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #3 of 4 (permalink) Old 07-10-2011, 05:59 PM
Thank you so much
Alfredo
Hi Alfredo - Welcome to the forum
I'll agree with Marco about picking up a Milescraft base plate. Since you haven't got a base plate for a pattern, that's about the quickest way up the learning curve. Plus, you end up with a set of guide bushings, a centering pin and some rudimentary instructions. Chances are, since the router was part of a table package, it never had a base plate included with it. As far as the table goes, most of the little plastic ones Sears hawks make good footstools but little else. As Marco indicated, you can pick up a table plate from several differents sources and either build your own table or purchase a manufactured one. Many of the manufactured ones are offered as a package which includes a fence and table plate.
Square baseplate for a newbie is actually a pretty good one. You will want to acquire an understanding of offsets to go with it though. Just like with bushings, the distance from the edge of the plate to the edge of the cut will change with the bit diameter.
Once again, welcome to the forum I counted four questions, you have 97 more
By the way, I don't think you are restricted from posting pictures. My understanding is the posting requirement just applies to links.
John Schaben
jschaben is offline
post #4 of 4 (permalink) Old 07-10-2011, 06:45 PM Thread Starter
First Name: Alfredo
Thank you so much guys I will go to Amazon and order the milescraft plate. I was not referring to table plates but a sub base plate that you use when hand holding the router like this one on this tread
Amalgam is offline
Centering your router on a mounting plate Mike Table-mounted Routing 61 01-08-2016 10:28 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Router plate as base plate?? xplorx4 General Routing 6 05-24-2009 06:19 PM
