Clamping of Straight Edge - Router Forums
post #1 of 7 (permalink) Old 07-23-2011, 10:28 AM Thread Starter
First Name: Ross
Default Clamping of Straight Edge
I've been doing some dados and flush cuts with my router for some closet shelving I'm making out of melamine. But I've had a hell of a time (also in the past with plywood) with keeping my straight edge stationary. Right now I'm using a 24" square.
To hold that down, I've tried using the big long Irwin pistol grip bar clamps, and I've tried some smaller ratcheting ones, but neither has been consistent in holding. I've thought about using C-clamps, but feel like those might cause some damage to the wood, and using a space block with that seems like it would be even more prone to slipping.
Just looking for some guidance on how others can consistently get a fixed straight edge.
Thanks in advance!
ross.anderson is offline
post #2 of 7 (permalink) Old 07-23-2011, 03:18 PM
First Name: gary
Along with the grips, apply some double-stick tape. Carpet tape would be the extreme.
If the length isn't too great, you could also get some of that sanding matting. It is actually carpet padding ---- rubbery with bubbles. Just don't get the thick stuff. With no clamps, it will grip a piece of wood while you work it over with a vibrating sander.
garycurtis is offline
post #3 of 7 (permalink) Old 07-23-2011, 03:24 PM
Marco's Avatar
If I understand correctly, you are using a 24" framing square for the edge of your router base to ride against so you can get a straight cut and the framing square is moving after clamping?
There are several ways to get a straight cut and I'm sure others will add...
I would use your 24" square to make sure another piece of wood is straight and clamp that piece of wood to be used for the router to ride against. You can also use factory edges of sheet goods as generaly they are straight just double check it with your square.
Also if you plan on making more dado's a dado jig would save a lot of time and aggravation. Google Dado Jig and several will come up here's one that some like Router Workshop: shelf dado jig
Hope this helps
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #4 of 7 (permalink) Old 07-24-2011, 08:44 AM
Ross, there are a couple of reasons you are getting the shifting. Consider that Melamine is very slick; using double sided carpet tape is a good solution as mentioned by Gary. Different types of clamps have different clamping pressures. Qucik Grip style clamps work well for glue ups where you want to hold the materials together and not squeeze out your glue. F style clamps develop more clamping pressure and C clamps provide the most. To prevent marring your surface when using these clamps add a wooden spacer; this will prevent crushing and allow greater clamping pressure to hold your work piece securely.
post #5 of 7 (permalink) Old 09-01-2011, 07:44 AM
argoknot's Avatar
First Name: john
I use a clamp guide. It works for me.
WoodRiver Clamp Guides - Woodcraft.com
Today is the first day of the rest of your life. Live it to it's fullest.
Making sawdust by the sea in Massachusetts
argoknot is offline
post #6 of 7 (permalink) Old 09-01-2011, 03:15 PM
Bargains Finder
First Name: Tommy
I'd recommend you purchase a Pro Grip 24 inch clamp from Peachtree Woodworking. They work perfect as a guide such as you describe and as it just so happens is on sale this weekend for $19.99 + shippin. I happen to have a complete set of these fine well built clamps and highly recommend them to others as they are strong as well as versatile. Heres a link to the sale. They are about 15 rows down on the right hand side, Edirect Special - Peachtree Woodworking Supply, Inc.
Tommyt654 is offline
post #7 of 7 (permalink) Old 09-01-2011, 04:17 PM
Honored Member
First Name: pat
Clamping down is the same as adding weight. Adding wt. frustrates the slip & slide alright but it is not the way to stop stuff from pivoting!
So what? There are 12 degrees of freedom of a work piece on a flat surface!
In/out, l/r, up/dn and 3 rotational components (cw/ccw) relating to the 3 axes of the work or fence, adds up to 12.
So there is a lot of opportunity for the work to move.
A couple of sticks clamped against the back of your guide would help.
But & notwithstanding, clamp down sticks and routers zipping along them provide a lousy means of steering the cutter from point A to ponit B.
Cleats, clamps, stops, fences, high friction surfaces will add & abet.
But be advised, clamping down, by itself, is a recipe for slip/slide city.
Quillman is offline
How to keep a straight edge nice Kelly Rittgers Tools and Woodworking 12 11-07-2010 07:41 PM
How do you make a straight edge tool? sofasurfer Jigs and Fixtures 45 04-30-2010 04:05 PM
Jig for Edge Drawer Pull Inlays Troy_Utah Jigs and Fixtures 9 01-30-2010 07:05 AM
Straight Edge S Bolton General Routing 7 01-06-2008 12:50 PM
